virtualbox + zfs jail snapshot
marian78
i have one question, maybe someone know answer (freenas v9.2.1.9 x64, 24G ram, XEON cpu).
Can ZFS snapshot of virtualbox jail cause freezing windows virtual machine (windows task mgr show before freeze 100% disk usage)?
I tryed set storage controller of virtual machine to SATA, SAS with no luck. Also try IO cache on/off.
marian78
For now i testing about 4 days... After this week i will know what was problem.
kaipee
Did you ever figure out the problem?
I had a few VMs set up in phpVirtualBox but they often hang / crash. I just realised I had snapshots set up for both the /zstore/jails dataset along with datasets that are 'mounted' in the running VM.
Not sure if running ZFS snapshots on a dataset while they are mounted in a VM causes any issues.
kaipee
Yes, by default VBox enables host caching on IDE controllers - however my drives are on SATA controllers with host cache disabled.
marian78
Hi, for now i dont use ZFS snapshot. I decide to use rsync for backup to second server.
