Virtual Machine and Link Aggregation Connectivity Issues
techielathan
OS Version:
TrueNAS-12.0-U2.1
Motherboard make and model
ASRock X570 Phantom Gaming
CPU make and model
AMD Ryzen 5 3600 6-Core, 12-Thread Unlocked Desktop Processor with Wraith Stealth Cooler
RAM quantity
Crucial 64GB Desktop DDR4 2666 MHz UDIMM Memory Kit (2 x 32GB)
Hard drives
Boot Disk
1 - Crucial P5 250GB 3D NAND NVMe Internal SSD, up to 3400MB/s - CT250P5SSD8
NVMe_Data Pool - Stripe
1 - Western Digital 2TB WD Blue SN550 NVMe Internal SSD - Gen3 x4 PCIe 8Gb/s, M.2 2280, 3D NAND, Up to 2,600 MB/s - WDS200T2B0C
1 - Crucial P5 1TB 3D NAND NVMe Internal SSD, up to 3400MB/s - CT1000P5SSD8
Data Pool - RAIDZ2
6 - Seagate 16TB HDD Exos X16 7200 RPM 512e/4Kn SATA 6Gb/s 256MB Cache 3.5-Inch Enterprise Hard Drive (ST16000NM001G)
Hard disk controllers
StarTech.com 4 Port PCI Express 2.0 SATA III 6Gbps RAID Controller Card with HyperDuo SSD Tiering - PCIe SATA 3 Controller Adapter (PEXSAT34RH)
Graphic Cards
Gigabyte GeForce GT 710 2GB Graphic Cards and Support PCI Express 2.0 X8 Bus Interface. Graphic Cards GV-N710D5-2GL
Network Cards
1 Gbps Dual Port PCIe Network Card, Gigabit Ethernet Converged Adapter with Intel 82576 Chip, 2 RJ45 Ports PCI Express NIC Card for Server Support Windows / Windows Server / Linux / FreeBSD / DOS
Case
Rosewill 4U Server Chassis/Server Case/Rackmount Case, Metal Rack Mount Computer Case with 12 Hot Swap Bays & 5 Fans Pre-Installed (RSV-L4412) Black
Power Supply
SHARK TECHNOLOGY 1000W Black ATX12V EPS12 Silent 120mm Fan Gaming PC 2X PCI-E Power Supply ATX PSU
Currently I am having an issue with my Windows 10 Virtual Machines they are intermittingly losing Internet network connectivity. All network interfaces are combined together through Link aggregation into one interface. I have to reboot my TrueNAS server multiple time before I am able to get internet access through the Virtual Machines, but after utilizing the internet access through the virtual machine if I reboot again then the same problem occurs. At no time do I lose access to network resources. I can reference other devices on the network through my virtual machines without an issue. Below are the current configurations of the Turnables, Network Interfaces, and Virtual Machine that I am having the issue with. I have attached the log files for the server and screenshot of the Turnable, Network, and Virtual Machine configurations. Currently I have not identify any errors in the log file. Any insights on how to resolve this issue will be grateful.
  • Turnables-Network-Virtual Machine Configurations.zip
  • debug-Venom-20210327045942.tgz
