VIMAGE jail does not get ateway
shpokas
Hi there again,
any quick thought why VIMAGE jail does not get default gateway? epair0a interface seems to be fine.
[shpokas@smtp ~]$ ping www.freenas.org
PING edge.anycastcdn.net (188.165.6.11): 56 data bytes
ping: sendto: No route to host
If I try to add default route _after_ jail boots, I get "fib 0: Invalid argument"
root@smtp:~ # route add -net default 192.168.17.1
route: writing to routing socket: Invalid argument
add net default: gateway 192.168.17.1 fib 0: Invalid argument
I post below ifconfig output from FreeNAS and jail as well as jail config screen.
Thanks for any ideas!
FreeNAS ifconfig
[root@vfs] ~# ifconfig
bge0: flags=8943<UP,BROADCAST,RUNNING,PROMISC,SIMPLEX,MULTICAST> metric 0 mtu 1500
options=c0099<RXCSUM,VLAN_MTU,VLAN_HWTAGGING,VLAN_HWCSUM,VLAN_HWTSO,LINKSTATE>
ether a0:1d:48:c7:ca:94
media: Ethernet autoselect (1000baseT <full-duplex>)
status: active
bge1: flags=8943<UP,BROADCAST,RUNNING,PROMISC,SIMPLEX,MULTICAST> metric 0 mtu 1500
status: active
ipfw0: flags=8801<UP,SIMPLEX,MULTICAST> metric 0 mtu 65536
options=600003<RXCSUM,TXCSUM,RXCSUM_IPV6,TXCSUM_IPV6>
inet6 ::1 prefixlen 128
inet6 fe80::1%lo0 prefixlen 64 scopeid 0x7
lagg0: flags=8943<UP,BROADCAST,RUNNING,PROMISC,SIMPLEX,MULTICAST> metric 0 mtu 1500
inet 192.168.17.17 netmask 0xffffff00 broadcast 192.168.17.255
inet6 fe80::a21d:48ff:fec7:ca94%lagg0 prefixlen 64 scopeid 0x8
inet6 2001:470:de8e:0:a21d:48ff:fec7:ca94 prefixlen 64 autoconf
inet6 2001:470:27:3ab:a21d:48ff:fec7:ca94 prefixlen 64 autoconf
inet 192.168.17.4 netmask 0xffffff00 broadcast 192.168.17.255
nd6 options=23<PERFORMNUD,ACCEPT_RTADV,AUTO_LINKLOCAL>
status: active
laggproto lacp lagghash l2,l3,l4
laggport: bge1 flags=1c<ACTIVE,COLLECTING,DISTRIBUTING>
laggport: bge0 flags=1c<ACTIVE,COLLECTING,DISTRIBUTING>
ether 02:c0:75:36:94:00
nd6 options=1<PERFORMNUD>
member: epair0a flags=143<LEARNING,DISCOVER,AUTOEDGE,AUTOPTP>
ifmaxaddr 0 port 10 priority 128 path cost 2000
member: lagg0 flags=143<LEARNING,DISCOVER,AUTOEDGE,AUTOPTP>
ifmaxaddr 0 port 8 priority 128 path cost 20000
epair0a: flags=8943<UP,BROADCAST,RUNNING,PROMISC,SIMPLEX,MULTICAST> metric 0 mtu 1500
options=8<VLAN_MTU>
ether 02:00:ea:00:0a:0a
status: active
Jail ifconfig
epair0b: flags=8843<UP,BROADCAST,RUNNING,SIMPLEX,MULTICAST> metric 0 mtu 1500
options=8<VLAN_MTU>
ether 02:78:8c:00:0b:0b
inet 192.168.17.3 netmask 0xffffff00 broadcast 192.168.17.255
shpokas
Found this in boot log - could it be related?
ng_ether_ifnet_arrival_event: can't re-name node epair0b
ifa_del_loopback_route: deletion failed
D
dlavigne
Guest
Might be. Please create a bug report at bugs.freenas.org and post the issue number here.
