t1nais
- Jul 6, 2013
Hi, I just installed FreeNAS on a box I bought and my write performance is non-existent. I have a raid z2 setup across 6x WD Red 3TB disks. The machine is a quad core, 32GB RAM, Gb NIC. I setup a CIFS share and am only getting 1MB/second write speed. I am attempting to copy from my Win 7 machine to the FreeNAS box. Any ideas on why it could be so slow? Below is an iperf I ran from my Win 7 laptop to the FreeNAS box, and even the wireless gets 23MB/s, so I don't think my router/network is the problem (otherwise I should be topping out at 20MB/s at least).
Hostname freenas.local
Build FreeNAS-8.3.1-RELEASE-p2-x64 (r12686+b770da6_dirty)
Platform AMD A10-5800K APU with Radeon(tm) HD Graphics
Memory 31931MB
Disks:
[root@freenas /mnt/storage/Test]# dd if=/dev/zero of=./del.me bs=1024k count=25k 25600+0 records in 25600+0 records out 26843545600 bytes transferred in 50.484395 secs (531719665 bytes/sec)
~=531MB/sec
Wireless network (Win) to GB FreeNAS (I know, use the wire, I did, it's still slow. CIFS writing is 20x slower than the wireless even):
[root@freenas /mnt/storage/Test]# iperf -c 192.168.1.130 ------------------------------------------------------------ Client connecting to 192.168.1.130, TCP port 5001 TCP window size: 32.5 KByte (default) ------------------------------------------------------------ [ 6] local 192.168.1.221 port 42831 connected with 192.168.1.130 port 5001 [ ID] Interval Transfer Bandwidth [ 6] 0.0-10.0 sec 219 MBytes 184 Mbits/sec
~=23MB/sec
Thanks for any suggestions.
Also, compression off, all disks passed SMART and are online, max CPU load 2%, free RAM 14GB
Memory 31931MB
Disks:
~=531MB/sec
~=23MB/sec
