I need some Advice from the Pros
I want to reinstall an "old" Server from Core to Scale.
The Server has 10x14TB HDD and 2x120GB SSD.
At the Moment i use the following Layout:
2x RaidZ2 VDev and one Mirrored Vdev for the Installation.
I used it with NFS for a Proxmox Host.
Some VMs need WritePower for an SQL Server.
Iam not so happy with the overall IO Performance.
Wich Layout should i used for the best IO / Harddisk Failure Balance?
The Server is a HotSwap and SpareDisk are always available.
Thanks for advice
Thanks for advice
