Hello.
Box been up and running for approx 6 months with no issues.
Last week i started getting emails every 5 minutes from root:
Was pressed for time so just rebooted the server and off i went
All good again until this weekend.....
Again being sent emails every 5 minutes with the same output as above.
Reading around it because my /var is getting full apparently.
Here are my outputs
So i can see that the Samba dir is the biggest of the lot, but when i du inside of that it doesnt shed any light
Anybody help me determine whats filling my stick up and why please?
Thanks in advance
- Build: FreeNAS-8.3.1-RELEASE-p2-x64 (r12686+b770da6_dirty
- RAM: 16GB
- 2x 1TB raid setup
- Boots of an 8GB USB Stick
- Joined to a Windows AD
File "/usr/local/bin/graph.py", line 480, in <module>
GenerateInterfaceGraph()
File "/usr/local/bin/graph.py", line 135, in GenerateInterfaceGraph
'GPRINT:global_tot_tx:ca. %5.1lf%s Total\l'
rrdtool.error: Could not save png to '/tmp/graph/if-em0-1h.png'Was pressed for time so just rebooted the server and off i went
Here are my outputs
[root@MYNAS ~]# df /var Filesystem 512-blocks Used Avail Capacity Mounted on /dev/md2 305583 305466 -24329 109% /var
1 /var/.snap 1 /var/heimdal 1 /var/at/jobs 1 /var/at/spool 3 /var/at 1 /var/cron/tabs 2 /var/cron 1 /var/rwho 8 /var/backups 1 /var/preserve 609 /var/db/collectd/rrd/localhost/swap 1521 /var/db/collectd/rrd/localhost/memory 305 /var/db/collectd/rrd/localhost/uptime 1521 /var/db/collectd/rrd/localhost/cpu-0 2129 /var/db/collectd/rrd/localhost/processes 873 /var/db/collectd/rrd/localhost/load 7704 /var/db/collectd/rrd/localhost/df 14218 /var/db/collectd/rrd/localhost/interface 1521 /var/db/collectd/rrd/localhost/cpu-1 1521 /var/db/collectd/rrd/localhost/cpu-2 1521 /var/db/collectd/rrd/localhost/cpu-3 33444 /var/db/collectd/rrd/localhost 33445 /var/db/collectd/rrd 33446 /var/db/collectd 115 /var/db/fontconfig 2 /var/db/samba/smb_krb5 1 /var/db/samba/winbindd_privileged 8775 /var/db/samba 1 /var/db/portsnap 1 /var/db/pkg 1 /var/db/ipf 1 /var/db/freebsd-update 1 /var/db/ports 1 /var/db/entropy 2 /var/db/dbus 1 /var/db/nut 484 /var/db/graphs/hourly 411 /var/db/graphs/daily 457 /var/db/graphs/weekly 473 /var/db/graphs/monthly 473 /var/db/graphs/yearly 2299 /var/db/graphs 44647 /var/db 1 /var/run/wpa_supplicant 1 /var/run/ppp 1 /var/run/named 2 /var/run/proftpd 1 /var/run/samba/nmbd 5 /var/run/samba 2 /var/run/dbus 2 /var/run/avahi-daemon 50 /var/run 2 /var/crash 1 /var/tmp/vi.recover 1 /var/tmp/.cache/.snap 138 /var/tmp/.cache/.samba 169 /var/tmp/.cache/.query 121 /var/tmp/.cache/.ldap/.activedirectory/.local/.users/MYDOMAIN 122 /var/tmp/.cache/.ldap/.activedirectory/.local/.users 145 /var/tmp/.cache/.ldap/.activedirectory/.local/.groups/MYDOMAIN 146 /var/tmp/.cache/.ldap/.activedirectory/.local/.groups 269 /var/tmp/.cache/.ldap/.activedirectory/.local 129 /var/tmp/.cache/.ldap/.activedirectory/.users/MYDOMAIN 130 /var/tmp/.cache/.ldap/.activedirectory/.users 145 /var/tmp/.cache/.ldap/.activedirectory/.groups/MYDOMAIN 146 /var/tmp/.cache/.ldap/.activedirectory/.groups 546 /var/tmp/.cache/.ldap/.activedirectory 547 /var/tmp/.cache/.ldap 856 /var/tmp/.cache 1 /var/tmp/.winbindd 1 /var/tmp/nginx/proxy_temp 1 /var/tmp/nginx/fastcgi_temp 1 /var/tmp/nginx/uwsgi_temp 1 /var/tmp/nginx/scgi_temp 5 /var/tmp/nginx 1 /var/tmp/firmware 1967 /var/tmp/graph 2847 /var/tmp 1 /var/empty 1 /var/audit 1 /var/mail 1 /var/named/etc/namedb/master 1 /var/named/etc/namedb/slave 1 /var/named/etc/namedb/working 1 /var/named/etc/namedb/dynamic 5 /var/named/etc/namedb 6 /var/named/etc 1 /var/named/var/stats 1 /var/named/var/log 1 /var/named/var/run/named 2 /var/named/var/run 1 /var/named/var/dump 6 /var/named/var 1 /var/named/dev 14 /var/named 1 /var/account 1 /var/agentx 1 /var/log/samba/cores/nmbd 1 /var/log/samba/cores/smbd 1 /var/log/samba/cores/winbindd 4 /var/log/samba/cores 254736 /var/log/samba 1 /var/log/proftpd 255440 /var/log 1 /var/spool/lock 1 /var/spool/output/lpd 2 /var/spool/output 1 /var/spool/opielocks 1 /var/spool/lpd 1 /var/spool/samba 1 /var/spool/mqueue 8 /var/spool 1 /var/games 2 /var/msgs 1 /var/yp 161 /var/etc/private 162 /var/etc 12 /var/home/domainuser1 12 /var/home/domainuser2 12 /var/home/domainuser3 12 /var/home/domainuser4 12 /var/home/domainuser5 12 /var/home/domainuser6 12 /var/home/domainuser7 12 /var/home/domainuser8 12 /var/home/domainuser9 12 /var/home/domainuser10 12 /var/home/domainuser11 12 /var/home/domainuser12 12 /var/home/domainuser13 12 /var/home/domainuser14 12 /var/home/domainuser15 12 /var/home/domainuser16 12 /var/home/domainuser17 205 /var/home 303403 /var
[root@MYNAS /var/log/samba]# du /var/log/samba 1 /var/log/samba/cores/nmbd 1 /var/log/samba/cores/smbd 1 /var/log/samba/cores/winbindd 4 /var/log/samba/cores 254736 /var/log/samba
Thanks in advance
