iSCSIinitiator
 - Jul 17, 2014
Question:
What, if any, are the stability concerns with running a v28 zpool on FreeNAS 9.2.1.6?
Background
I've been running multiple FreeNAS servers for a couple of months now, all with v5000 zpools and all now at FreeNAS 9.2.1.6. I've followed the (very helpful) advice in the forum here and am trying to do all the right things (plenty of ECC RAM, periodic scrubs, etc.). Things are going well so far.
I'm about to set up a new multi-server FreeNAS system which for me will be The Big One - storing lots of important data and acting as a domain controller. The system will be multi-server, as I'll be replicating and rsyncing data to a twin config in another location and a siloed (likely Linux XFS) fail-safe, respectively.
I really want to do everything I can to protect my data and facilitate recovery, should it be necessary. I know I want 9.2.1.6 because the SAMBA 4 DC stuff is critical. However, I also understand that FreeNAS is ahead of many other distributions in its zpool v5000 code base (e.g., hole_birth) and SAMBA 4 integration (e.g., better Windows ACL support) - some of the many reasons I love FreeNAS.
Because of all these factors, I'm contemplating creating a v28 zpool with FreeNAS 8.3.2 and immediately detaching the zpool. Then, on a clean install of FreeNAS 9.2.1.6, I'd auto-import the zpool (but not upgrade it) and then move forward from there.
I've already tried some basic tests with this, and FreeNAS 9.2.1.6 seemed to work with the v28 zpool, and I could even detach the zpool and move the disks back to an 8.3.2 system and auto-import it. I would never want to do this on a production system unless there was a major issue or I was performing a planned upgrade, but I really like the idea that the data/disks would be interoperable with other distributions if I needed them for recovery, etc. While my other servers run RAIDZ2, I'm planning to set up the twin FreeNAS boxes here each with zpools striped across vdevs with 4-way mirrors for increased redundancy and flexibility.
I understand that v5000 zpools have lz4 and other features that I would forfeit using v28, but I don't need these other features, as far as I know. What I'm really concerned about, though, is FreeNAS 9.2.1.6's comfort and stability with a v28 zpool. If replication from a 9.2.1.6 system with a v28 pool to another 9.2.1.6 system with a v28 pool is dangerous, or if Windows ACLs break on a v28 pool, those sorts of things would be dealbreakers for me.
Any thoughts or suggestions would be greatly appreciated.
Thanks very much.
Background
Thanks very much.
