I'm considering building a FreeNAS system with an older motherboard/cpu.
SuperMicro X8SIL-F
Xeon x3470
16 to 32GB ECC RAM
(6) 3TB WD Reds. (RaidZ2)
Seasonic 550 power supply
Fractal Design Node 804 case
The boot will either be a flash drive or an SSD hooked up to USB. Probably mirrored.
My usage needs are not that great as right now I have about 4 of 6TB used and this would double the space. I would be using Plex (2 streams at max) with it but the video is already transcoded. It would be used for backups and drive maps from a couple PCs but the usage would be low. I'm also considering a couple jails. Mostly just to have a FreeBSD system handy when I want one to play around on and maybe run a minecraft server for my kids down the road. I don't need a big powerhouse system so that's why I was thinking of going this way.
I just want to know if this would be viable (to me it seems it is but I've never built a FreeNAS system) and see if anyone had advice for making it better.
Thanks for any advice.
Jason
SuperMicro X8SIL-F
Xeon x3470
16 to 32GB ECC RAM
Jason
