daninmanchester
 - Feb 9, 2019
I have windows datasets and a windows SMB share which I am trying to reset permissions on.
Due to the volume of data for whatever reason, this isn't working over the LAN from a windows PC which borks some hours into the process.
So now I have the delightful command line to deal with and I am struggling to find good examples. Most seem to be around linux and not necessarily supported on freeNas and also focus on linux use ,group, other style permissions.
I have drawn a diagram of what I'm trying to achieve :
I'd like to know how I apply these removing any existing permission so some examples of A, B, C and D would be massively helpful.
If I have any existing unix permissions would I need to remove these and if so how?
I figured I should be using setfacl?
Also if you had some examples of how then to remove a user/group from a folder that would be helpful too.
I've experimented with various things but struggled to achieve the desired results.
thanks!
thanks!
