User added by shell does not exist
KrisStaf88
In FreeNAS GUI I opened shell console, to add new user by command:
[root@freenas] ~# adduser testuser
and then, I followed a step by step in next prompted questions/settings as here:
http://fernandoquiros.com/articles/160306-git-web-server-for-freenas/add-user.png
Finally I got result text as in above pictures.
Now I see home directory eg:
/home/testuser
but in GUI and in a list of users, by command:
cat /etc/passwd
there is no 'newuser' created
1. This is a normal behavior, this is a some secure ?
2. Should I to add a new user (by command) only in the shell console opened in a jail ? --> then new user will be correctly added ?
Please explain me anybody. I read section ACCOUNTS in the Freenas manual, but there is no explanation.
Cheers.
K
Jailer
Not strong, but bad
Why on earth would you do that when there is a section in the GUI for user management. The reason you can't see the user in the GUI is because you created it at the CLI. In doing so you skipped the middleware layer and the GUI has no way of knowing or tracking what you are doing.
Follow the manual and use the GUI for user management.
http://doc.freenas.org/11/account.html
In FreeNas GUI I opened shell console, to add new user by command:
Why did you do that? Don't use the CLI to change things behind the GUI's back.
Chris Moore
What you have to understand about FreeNAS is that despite the fact it's built on BSD Unix and all your BSD Unix knowledge does apply, if you don't use the appliance that was built on top of BSD the way the appliance was designed to work then you're going to break it.
KrisStaf88
thank you All for reply.
I added a new user by CLI not GUI, it was a one step in some procedures/tutorial (Gogs for FreeNas). I made a mistake, because I should do/add by CLI, it in a new jail. A jail can be simply deleted with all modifications and created again.
That made me curious.
BTW "software" in my work has a the middleware, that "see" low level chanches and "see" changes done by GUI.
Chris Moore
They are working to make this better, but it is not perfect yet.
