- May 13, 2015
TL;DR: The Windows version of Supermicro's IPMIView 2.12 and IPMITools 2.16 install their own copy of stunnel, ignoring and disabling any existing stunnel installation! So if you are among the small contingent of people who use both stunnel and Supermicro server management tools on Windows machines, caveat utilitor!
I found this out the hard way, of course.
Recently I upgraded the IPMI firmware on my X10SL7-F from Redfish v3.27 to 3.45, after which I could no longer connect to the server with the IPMIView KVM console. So I upgraded IPMIView to v2.12 and the KVM connection started working again. Yay! I thought. Success! I thought. But no...
None of my VNC or email connections worked any longer. After a little digging around, I figured out that the new version of IPMIView had installed its own version of stunnel; blithely replacing itself as the Windows stunnel service, and breaking all of my email and VNC connections in the process. And what's more, it seems to do this on an ad hoc basis, creating the stunnel setup in a temporary directory in the Application Data directory under my user directory. Yikes! Kludge to the max!
So... I uninstalled IPMIView, re-installed the older version (2.11), and re-flashed the IPMI firmware to version 3.27. Now everything works... except that I can't connect to the IPMI web interface; IPMIView and the KVM module work fine, I can ping the IPMI IP address of the server, I can use the IPMITools and IPMIUtil against it... but no web interface. It did work when the firmware was at v3.45, FWIW. And it was working before I started this merry-go-round.
Evidently the Redfish v3.45 firmware requires an SSL-encrypted connection and Supermicro chose a kludgy stunnel installation to set it up. Guess I'm stuck with the current versions of everything until they change this.
IPMIView versions 2.11 don't have this problem. I also checked the IPMITools archives and version 2.16 includes the stunnel snafu; previous versions do not.
