movieman03
 - Jan 17, 2015
I am new. Below is my setup:
Fractal Node Case 304
Celeron G1820
H97 ASRock m-ITX
8GB (2x4) Mushkin Blackline
Transcend 128GB OS
3TB (3 x 1.5) Seagate Barracude
5TB USB3 External Seagate
For the most part everything seems to work. However, there is something weird.
I am moving my files (2.5TB) from my RAID array to my 5TB external drive which is connected to the NAS box.
I setup a windows share on the array and a windows share on the external. I am on win8.1. I see both of the shares and then I just copy/pasted the files. Initially the speeds are up to 70MB/s and everything seems fine. Then the speed slowly goes down to 0MB/s and sits there for several seconds and works its way back up to 70MB/s and then the cycle repeats. So it will take about a day for the files to copy over and I have to babysit it. because my network connection from my win8.1 machine timed out once and after disabling/enabling it I was able to start the copy process over again.
1. Why is this happening?
2. Is there an other/easier/better way to copy files on the FreeNAS box?
Thank you
Celeron G1820
H97 ASRock m-ITX
Transcend 128GB OS
Thank you
