USB Keyboard not working at "Console Set-up"
mr_k
hi all,
i was running freenas from a USB pendrive before so i decided to give freenas 8 a shot.
everything boots fine, when i get to the freenas boot choice screen, my keyboard works (pausing the timer, choosing an option), however when the installation screen appears (console setup) its as if the system hangs, when i press num/caps or scroll the lights dont respond, stay lit.
i also tried freenas 7 to check if it was just a problem with 8, but its the same.
can anyone help please?
thanks,
Milhouse
Have you checked your BIOS for USB compatibility settings, might be worth a shot.
mr_k
hmm i will have a look but i dont see why it works on the first boot screen then not in the second console ?
Milhouse
Ah sorry, missed that. I do know that FreeNAS doesn't play well with USB3, so you may have to disable that if your motherboard has it. Some info on your hardware would be useful, you know, when diagnosing hardware related issues.
mr_k
my setup is a Dell Optiplex 745
Cpu: Intel Core2 Duo E600 Series
1GB RAM
Maxell 1 GB USB Stick
Dell USB Keyboard
