ChiknNutz
- Nov 6, 2015
This morning I rec'd a message about the boot volume being degraded. I have two devices mirrored. I have had this issue a couple time past, and sometimes a reboot or scrub is all that is needed. Not this time, so I detached the degraded one and attempted to reattach it. Now the systems says it doesn't have enough room to mirror it?! Huh? it is the exact same device that was just plugged in. Okay, so tried to reformat the bad one and reattach, same message. Okay, I have a brand new EXACT same replacement USB drive...same error message. What the heck? I mean they are all identical 16GB USB flash drives.
Environment: Software Version: FreeNAS-11.1-U5 (8e2a858a1) Request Method: POST Request URL: http://192.168.254.66/system/bootenv/pool/attach/?label=gptid/a5cc80e7-97d1-11e5-992a-0cc47a7a3337 Traceback: File "./freenasUI/system/forms.py" in done 297. c.call('boot.attach', devname, {'expand': self.cleaned_data['expand']}, job=True) File "/usr/local/lib/python3.6/site-packages/middlewared/client/client.py" in call 457. raise ClientException(job['error'], trace=job['exception']) File "/usr/local/lib/python3.6/site-packages/django/core/handlers/exception.py" in inner 42. response = get_response(request) File "/usr/local/lib/python3.6/site-packages/django/core/handlers/base.py" in _legacy_get_response 249. response = self._get_response(request) File "/usr/local/lib/python3.6/site-packages/django/core/handlers/base.py" in _get_response 178. response = middleware_method(request, callback, callback_args, callback_kwargs) File "./freenasUI/freeadmin/middleware.py" in process_view 162. return login_required(view_func)(request, *view_args, **view_kwargs) File "/usr/local/lib/python3.6/site-packages/django/contrib/auth/decorators.py" in _wrapped_view 23. return view_func(request, *args, **kwargs) File "./freenasUI/system/views.py" in bootenv_pool_attach 499. form.done() File "./freenasUI/system/forms.py" in done 299. raise MiddlewareError(str(e)) File "./freenasUI/system/forms.py" in done 299. raise MiddlewareError(str(e)) Exception Type: MiddlewareError at /system/bootenv/pool/attach/ Exception Value: [MiddlewareError: [EFAULT] The device called SanDisk Cruzer Fit (14.56 GB, 30529536 sectors does not have enough space to mirror the old device SanDisk Cruzer Fit (14.56 GB, 30529536 sectors). Please use a larger device.]
