USB-boot Fail
Jacopx
Buongiorno,
this night i have received this report:
The boot volume state is DEGRADED: One or more devices could not be opened. Sufficient replicas exist for the pool to continue functioning in a degraded state.
I know what it means! I'm go to see in /var/log/messages and it's show:
Jul  4 01:50:46 FreeNAS ugen3.3: <SanDisk> at usbus3
Jul  4 01:50:46 FreeNAS umass0: <SanDisk Ultra Fit, class 0/0, rev 2.10/1.00, addr 3> on usbus3
Jul  4 01:50:46 FreeNAS umass0:  SCSI over Bulk-Only; quirks = 0x8100
Jul  4 01:50:46 FreeNAS umass0:8:0:-1: Attached to scbus8
Jul  4 01:50:46 FreeNAS usb_alloc_device: Failure selecting configuration index 0:USB_ERR_STALLED, port 8, addr 4 (ignored)
Jul  4 01:50:46 FreeNAS ugen3.4: <SanDisk> at usbus3
Jul  4 01:50:46 FreeNAS da0 at umass-sim0 bus 0 scbus8 target 0 lun 0
Jul  4 01:50:46 FreeNAS da0: <SanDisk Ultra Fit 1.00> Removable Direct Access SPC-4 SCSI device
Jul  4 01:50:46 FreeNAS da0: Serial Number 4C530001021027112172
Jul  4 01:50:46 FreeNAS da0: 40.000MB/s transfers
Jul  4 01:50:46 FreeNAS da0: 14832MB (30375936 512 byte sectors)
Jul  4 01:50:46 FreeNAS da0: quirks=0x2<NO_6_BYTE>
It's possible to reuse it? Or is it better to throw it?
This two stick have only 3 months... One is OK, but i think that it's too early for a FAIL! It could be related to the System Dataset destination? Is better to use some disks for it? :)
Thanks!
Mirfster
I would toss it... USB Sticks are pretty much "disposable" IMHO
If you mean a HDD or SSD as your boot device, then I would say "Yes". I prefer cheap old SSDs which are mirrored.
Jacopx
No, i'm speaking about the destination of the System Dataset!
