USB 3.1 gen2 (10Gbps) compatibility
russman
I searched and so far have been unsuccessful in finding any answers. Does anyone know if FreeNAS supports the above mentioned speed? My current install is 9.10.2-U3 and has an expansion card. When I do usbconfig, it does show the card but shows the speed as 5.0Gbps.
Thanks.
Chris Moore
Thanks.
You might have better luck if you update to the more recent version as it uses a newer version of the operating system and may include newer drivers.
Out of curiosity, why are you interested in USB?
