I have a USB 3.0 PCI Express Card that I wanted to use to hook up an external USB HDD to my newly built NAS-system (with FreeNAS 8.3 beta2 on) to transfer files to my NAS storage. Does anybody know how to make that work? Right now I only see the two internal HDDs that are in FreeNAS as zfs/mirror and the USB stikc from which I run FreeNAS
But I do not see the drive that is connected to that PCI-card.
My dmesg.boot has a line saying "pci3: <serial bus, USB> at device 0.0 (no driver attached)" - could that be the culprit? And if so, is there anything that can be done about it?
[root@freenas ~]# camcontrol devlist <ST3000DM001-9YN166 CC4B> at scbus0 target 0 lun 0 (pass0,ada0) <ST3000DM001-9YN166 CC4B> at scbus2 target 0 lun 0 (pass1,ada1) < USB Flash Memory 1.00> at scbus6 target 0 lun 0 (pass2,da0)
Copyright (c) 1992-2012 The FreeBSD Project.
Copyright (c) 1979, 1980, 1983, 1986, 1988, 1989, 1991, 1992, 1993, 1994
The Regents of the University of California. All rights reserved.
FreeBSD is a registered trademark of The FreeBSD Foundation.
FreeBSD 8.3-RELEASE-p4 #2 r240088M: Tue Sep 4 06:56:00 PDT 2012
root@build.ixsystems.com:/build/home/jpaetzel/8.3.0/os-base/amd64/build/home/jpaetzel/8.3.0/FreeBSD/src/sys/FREENAS.amd64 amd64
Timecounter "i8254" frequency 1193182 Hz quality 0
CPU: AMD Athlon(tm) II X2 250 Processor (3013.55-MHz K8-class CPU)
Origin = "AuthenticAMD" Id = 0x100f63 Family = 10 Model = 6 Stepping = 3
Features=0x178bfbff<FPU,VME,DE,PSE,TSC,MSR,PAE,MCE,CX8,APIC,SEP,MTRR,PGE,MCA,CMOV,PAT,PSE36,CLFLUSH,MMX,FXSR,SSE,SSE2,HTT>
Features2=0x802009<SSE3,MON,CX16,POPCNT>
AMD Features=0xee500800<SYSCALL,NX,MMX+,FFXSR,Page1GB,RDTSCP,LM,3DNow!+,3DNow!>
AMD Features2=0x837ff<LAHF,CMP,SVM,ExtAPIC,CR8,ABM,SSE4A,MAS,Prefetch,OSVW,IBS,SKINIT,WDT,NodeId>
TSC: P-state invariant
real memory = 8589934592 (8192 MB)
avail memory = 8246448128 (7864 MB)
ACPI APIC Table: <032312 APIC1805>
FreeBSD/SMP: Multiprocessor System Detected: 2 CPUs
FreeBSD/SMP: 1 package(s) x 2 core(s)
cpu0 (BSP): APIC ID: 0
cpu1 (AP): APIC ID: 1
WARNING: VIMAGE (virtualized network stack) is a highly experimental feature.
ACPI Warning: Optional field Pm2ControlBlock has zero address or length: 0x0000000000000000/0x1 (20101013/tbfadt-655)
ioapic0 <Version 2.1> irqs 0-23 on motherboard
kbd1 at kbdmux0
hpt27xx: RocketRAID 27xx controller driver v1.0 (Sep 4 2012 06:55:49)
cryptosoft0: <software crypto> on motherboard
aesni0: No AESNI support.
acpi0: <032312 XSDT1805> on motherboard
acpi0: [ITHREAD]
acpi0: Power Button (fixed)
acpi0: reservation of fee00000, 1000 (3) failed
acpi0: reservation of ffb80000, 80000 (3) failed
acpi0: reservation of fec10000, 20 (3) failed
acpi0: reservation of fed40000, 5000 (3) failed
acpi0: reservation of 0, a0000 (3) failed
acpi0: reservation of 100000, d7e00000 (3) failed
Timecounter "ACPI-fast" frequency 3579545 Hz quality 1000
acpi_timer0: <32-bit timer at 3.579545MHz> port 0x808-0x80b on acpi0
cpu0: <ACPI CPU> on acpi0
cpu1: <ACPI CPU> on acpi0
acpi_hpet0: <High Precision Event Timer> iomem 0xfed00000-0xfed003ff on acpi0
Timecounter "HPET" frequency 14318180 Hz quality 900
pcib0: <ACPI Host-PCI bridge> port 0xcf8-0xcff on acpi0
pci0: <ACPI PCI bus> on pcib0
pcib1: <ACPI PCI-PCI bridge> irq 18 at device 2.0 on pci0
pci1: <ACPI PCI bus> on pcib1
vgapci0: <VGA-compatible display> mem 0xf8000000-0xfbffffff,0xd8000000-0xdfffffff,0xfd000000-0xfdffffff irq 18 at device 0.0 on pci1
pcib2: <ACPI PCI-PCI bridge> irq 16 at device 4.0 on pci0
pci2: <ACPI PCI bus> on pcib2
re0: <RealTek 8168/8111 B/C/CP/D/DP/E/F PCIe Gigabit Ethernet> port 0xe800-0xe8ff mem 0xf6fff000-0xf6ffffff,0xf6ff8000-0xf6ffbfff irq 16 at device 0.0 on pci2
re0: Using 1 MSI-X message
re0: ASPM disabled
re0: Chip rev. 0x2c800000
re0: MAC rev. 0x00000000
miibus0: <MII bus> on re0
rgephy0: <RTL8169S/8110S/8211B media interface> PHY 1 on miibus0
rgephy0: none, 10baseT, 10baseT-FDX, 10baseT-FDX-flow, 100baseTX, 100baseTX-FDX, 100baseTX-FDX-flow, 1000baseT, 1000baseT-master, 1000baseT-FDX, 1000baseT-FDX-master, 1000baseT-FDX-flow, 1000baseT-FDX-flow-master, auto, auto-flow
re0: Ethernet address: 30:85:a9:43:b0:e3
re0: [ITHREAD]
pcib3: <ACPI PCI-PCI bridge> irq 18 at device 10.0 on pci0
pci3: <ACPI PCI bus> on pcib3
ahci0: <ATI IXP700 AHCI SATA controller> port 0xd000-0xd007,0xc000-0xc003,0xb000-0xb007,0xa000-0xa003,0x9000-0x900f mem 0xf7fffc00-0xf7ffffff irq 22 at device 17.0 on pci0
ahci0: [ITHREAD]
ahci0: AHCI v1.10 with 4 3Gbps ports, Port Multiplier supported
ahcich0: <AHCI channel> at channel 0 on ahci0
ahcich0: [ITHREAD]
ahcich1: <AHCI channel> at channel 1 on ahci0
ahcich1: [ITHREAD]
ahcich2: <AHCI channel> at channel 2 on ahci0
ahcich2: [ITHREAD]
ahcich3: <AHCI channel> at channel 3 on ahci0
ahcich3: [ITHREAD]
ohci0: <OHCI (generic) USB controller> mem 0xf7ffe000-0xf7ffefff irq 16 at device 18.0 on pci0
ohci0: [ITHREAD]
usbus0: <OHCI (generic) USB controller> on ohci0
ohci1: <OHCI (generic) USB controller> mem 0xf7ffd000-0xf7ffdfff irq 16 at device 18.1 on pci0
ohci1: [ITHREAD]
usbus1: <OHCI (generic) USB controller> on ohci1
ehci0: <EHCI (generic) USB 2.0 controller> mem 0xf7fff800-0xf7fff8ff irq 17 at device 18.2 on pci0
ehci0: [ITHREAD]
usbus2: EHCI version 1.0
usbus2: <EHCI (generic) USB 2.0 controller> on ehci0
ohci2: <OHCI (generic) USB controller> mem 0xf7ffc000-0xf7ffcfff irq 18 at device 19.0 on pci0
ohci2: [ITHREAD]
usbus3: <OHCI (generic) USB controller> on ohci2
ohci3: <OHCI (generic) USB controller> mem 0xf7ffb000-0xf7ffbfff irq 18 at device 19.1 on pci0
ohci3: [ITHREAD]
usbus4: <OHCI (generic) USB controller> on ohci3
ehci1: <EHCI (generic) USB 2.0 controller> mem 0xf7fff400-0xf7fff4ff irq 19 at device 19.2 on pci0
ehci1: [ITHREAD]
usbus5: EHCI version 1.0
usbus5: <EHCI (generic) USB 2.0 controller> on ehci1
pci0: <serial bus, SMBus> at device 20.0 (no driver attached)
atapci0: <ATI IXP700/800 UDMA133 controller> port 0x1f0-0x1f7,0x3f6,0x170-0x177,0x376,0xff00-0xff0f at device 20.1 on pci0
ata0: <ATA channel> at channel 0 on atapci0
ata0: [ITHREAD]
ata1: <ATA channel> at channel 1 on atapci0
ata1: [ITHREAD]
pci0: <multimedia, HDA> at device 20.2 (no driver attached)
isab0: <PCI-ISA bridge> at device 20.3 on pci0
isa0: <ISA bus> on isab0
pcib4: <ACPI PCI-PCI bridge> at device 20.4 on pci0
pci4: <ACPI PCI bus> on pcib4
ohci4: <OHCI (generic) USB controller> mem 0xf7ffa000-0xf7ffafff irq 18 at device 20.5 on pci0
ohci4: [ITHREAD]
usbus6: <OHCI (generic) USB controller> on ohci4
amdtemp0: <AMD K8 Thermal Sensors> on hostb4
acpi_button0: <Power Button> on acpi0
atrtc0: <AT realtime clock> port 0x70-0x71 irq 8 on acpi0
ppc0: <Parallel port> port 0x378-0x37f irq 7 on acpi0
ppc0: Generic chipset (NIBBLE-only) in COMPATIBLE mode
ppc0: [ITHREAD]
ppbus0: <Parallel port bus> on ppc0
lpt0: <Printer> on ppbus0
lpt0: [ITHREAD]
lpt0: Interrupt-driven port
acpi_hpet1: <High Precision Event Timer> iomem 0xfed00000-0xfed003ff on acpi0
device_attach: acpi_hpet1 attach returned 12
atkbdc0: <Keyboard controller (i8042)> port 0x60,0x64 irq 1 on acpi0
atkbd0: <AT Keyboard> irq 1 on atkbdc0
kbd0 at atkbd0
atkbd0: [GIANT-LOCKED]
atkbd0: [ITHREAD]
psm0: <PS/2 Mouse> irq 12 on atkbdc0
psm0: [GIANT-LOCKED]
psm0: [ITHREAD]
psm0: model IntelliMouse, device ID 3
uart0: <16550 or compatible> port 0x3f8-0x3ff irq 4 flags 0x10 on acpi0
uart0: [FILTER]
sc0: <System console> at flags 0x100 on isa0
sc0: VGA <16 virtual consoles, flags=0x300>
vga0: <Generic ISA VGA> at port 0x3c0-0x3df iomem 0xa0000-0xbffff on isa0
acpi_throttle0: <ACPI CPU Throttling> on cpu0
hwpstate0: <Cool`n'Quiet 2.0> on cpu0
fuse4bsd: version 0.3.9-pre1, FUSE ABI 7.8
Timecounters tick every 1.000 msec
hpt27xx: no controller detected.
usbus0: 12Mbps Full Speed USB v1.0
usbus1: 12Mbps Full Speed USB v1.0
usbus2: 480Mbps High Speed USB v2.0
usbus3: 12Mbps Full Speed USB v1.0
usbus4: 12Mbps Full Speed USB v1.0
usbus5: 480Mbps High Speed USB v2.0
usbus6: 12Mbps Full Speed USB v1.0
ugen0.1: <ATI> at usbus0
uhub0: <ATI OHCI root HUB, class 9/0, rev 1.00/1.00, addr 1> on usbus0
ugen1.1: <ATI> at usbus1
uhub1: <ATI OHCI root HUB, class 9/0, rev 1.00/1.00, addr 1> on usbus1
ugen2.1: <ATI> at usbus2
uhub2: <ATI EHCI root HUB, class 9/0, rev 2.00/1.00, addr 1> on usbus2
ugen3.1: <ATI> at usbus3
uhub3: <ATI OHCI root HUB, class 9/0, rev 1.00/1.00, addr 1> on usbus3
ugen4.1: <ATI> at usbus4
uhub4: <ATI OHCI root HUB, class 9/0, rev 1.00/1.00, addr 1> on usbus4
ugen5.1: <ATI> at usbus5
uhub5: <ATI EHCI root HUB, class 9/0, rev 2.00/1.00, addr 1> on usbus5
ugen6.1: <ATI> at usbus6
uhub6: <ATI OHCI root HUB, class 9/0, rev 1.00/1.00, addr 1> on usbus6
uhub6: 2 ports with 2 removable, self powered
uhub0: 3 ports with 3 removable, self powered
uhub1: 3 ports with 3 removable, self powered
uhub3: 3 ports with 3 removable, self powered
uhub4: 3 ports with 3 removable, self powered
uhub2: 6 ports with 6 removable, self powered
uhub5: 6 ports with 6 removable, self powered
ugen2.2: <vendor 0x0930> at usbus2
umass0: <vendor 0x0930 USB Flash Memory, class 0/0, rev 2.00/1.00, addr 2> on usbus2
ada0 at ahcich0 bus 0 scbus0 target 0 lun 0
ada0: <ST3000DM001-9YN166 CC4B> ATA-8 SATA 3.x device
ada0: 300.000MB/s transfers (SATA 2.x, UDMA6, PIO 8192bytes)
ada0: Command Queueing enabled
ada0: 2861588MB (5860533168 512 byte sectors: 16H 63S/T 16383C)
ada1 at ahcich2 bus 0 scbus2 target 0 lun 0
ada1: <ST3000DM001-9YN166 CC4B> ATA-8 SATA 3.x device
ada1: 300.000MB/s transfers (SATA 2.x, UDMA6, PIO 8192bytes)
ada1: Command Queueing enabled
ada1: 2861588MB (5860533168 512 byte sectors: 16H 63S/T 16383C)
SMP: AP CPU #1 Launched!
da0 at umass-sim0 bus 0 scbus6 target 0 lun 0
da0: < USB Flash Memory 1.00> Removable Direct Access SCSI-2 device
da0: 40.000MB/s transfers
da0: 1909MB (3911616 512 byte sectors: 255H 63S/T 243C)
GEOM: da0s1: geometry does not match label (16h,63s != 255h,63s).
Trying to mount root from ufs:/dev/ufs/FreeNASs1a
ZFS filesystem version 5
ZFS storage pool version 28
