maximilian
 - Nov 18, 2011
I was trying to install FreeNas to a USB 3.0 device.
(see also http://forums.freenas.org/showthread.php?467-USB-3.0-Support-in-FreeNAS-8).
Since it didn't show up during the installation at all I put it back to the 2.0 port.
That solved the installation issue.
Now using it on 3.0 to boot it seems to use 2.0 speed only.
dmesg partially:
Its probably rather a linux question than a particular Freenas question.
Can anyone help/explain?
Hardware:
i3
intel dh61dl (2 x USB 3.0)
8 GB Ram (Kingston)
16 GB Kingston DT Ultimate G2 USB 3.0 Stick
2 WD, 1 Seagate HDDs for ZFS pool
Freenas 8.02 X64
The xhci(4) driver, which supports Extensible Host Controller Interface (xHCI) and USB 3.0, has been added.[r215944] in FreeBSD 8.2
dmesg partially:
usbus0: 480Mbps High Speed USB v2.0
usbus1: 4.8Gbps Super Speed USB v3.0
usbus2: 480Mbps High Speed USB v2.0
ugen1.1: <0x1033> at usbus1
uhub1: <0x1033 XHCI root HUB, class 9/0, rev 3.00/1.00, addr 1> on usbus1
uhub1: 4 ports with 4 removable, self powered (strange - got actually 2 usb 3.0 ports )
uhub0: 2 ports with 2 removable, self powered
uhub2: 2 ports with 2 removable, self powered
ugen1.2: <Kingston> at usbus1
umass0: <Kingston DT Ultimate G2, class 0/0, rev 2.10/1.10, addr 1> on usbus1
da0: <Kingston DT Ultimate G2 PMAP> Removable Direct Access SCSI-0 device
da0: 40.000MB/s transfers
da0: 15280MB (31293440 512 byte sectors: 255H 63S/T 1947C)
Hardware:
i3
8 GB Ram (Kingston)
Freenas 8.02 X64
