Hello!
I am trying to make a cheap home NAS. I have an Alix.2 system with two USB 3.0 ADATA CH11 500 Gb portable drives attached. The Alix motherboard supports USB 2.0 as is detected by FreeNAS:
The problem is that both hard drives are attached as USB 1.1 devices --using OHCI controller, not EHCI:
Everything works fine, but data transfers are way too slow!
I have tried with Debian (same hardware and same USB port) and it attaches as Hi-Speed (and I have checked the speed):
I come from Linux, so I have not very much knowledge about FreeBSD. Any clue on how can I force to use EHCI instead?
FreeNAS version: 8.2.0-RELEASE-p1-x86
(...) ohci0: <OHCI (generic) USB controller> mem 0xefffe000-0xefffefff irq 12 at device 15.4 on pci0 ohci0: [ITHREAD] usbus0: <OHCI (generic) USB controller> on ohci0 ehci0: <AMD CS5536 (Geode) USB 2.0 controller> mem 0xefffd000-0xefffdfff irq 12 at device 15.5 on pci0 ehci0: [ITHREAD] usbus1: EHCI version 1.0 usbus1: <AMD CS5536 (Geode) USB 2.0 controller> on ehci0 (...) usbus0: 12Mbps Full Speed USB v1.0 usbus1: 480Mbps High Speed USB v2.0 ugen0.1: <AMD> at usbus0 uhub0: <AMD OHCI root HUB, class 9/0, rev 1.00/1.00, addr 1> on usbus0 ugen1.1: <AMD> at usbus1 uhub1: <AMD EHCI root HUB, class 9/0, rev 2.00/1.00, addr 1> on usbus1 uhub0: 4 ports with 4 removable, self powered uhub1: 4 ports with 4 removable, self powered
ugen0.2: <ADATA> at usbus0 umass0: <ADATA CH11, class 0/0, rev 2.10/1.00, addr 2> on usbus0 da0 at umass-sim0 bus 0 scbus2 target 0 lun 0 da0: <ADATA CH11 2AR1> Fixed Direct Access SCSI-5 device da0: 1.000MB/s transfers da0: 476940MB (976773168 512 byte sectors: 255H 63S/T 60801C)
~ # usb-list Bus 01 Device 01: EHCI Host Controller [1d6b:0002] Level 00 Parent 00 Port 00 Class 09(hub ) Subclass 00 Protocol 00 Manufacturer: Linux 2.6.32-5-486 ehci_hcd Interface 00: Class 09(hub ) Subclass 00 Protocol 00 Driver hub Bus 01 Device 02: CH11 [125f:a11a] Level 01 Parent 01 Port 01 Class 00(>ifc ) Subclass 00 Protocol 00 Manufacturer: ADATA Interface 00: Class 08(mstor) Subclass 06 Protocol 50 Driver usb-storage Bus 02 Device 01: OHCI Host Controller [1d6b:0001] Level 00 Parent 00 Port 00 Class 09(hub ) Subclass 00 Protocol 00 Manufacturer: Linux 2.6.32-5-486 ohci_hcd Interface 00: Class 09(hub ) Subclass 00 Protocol 00 Driver hub
