MisterE2002
- Sep 5, 2015
Had some older server boards of asrock. The IPMI was horrible Java crap. Needed to download a file, later had to made java security exceptions. It just did not work when needed the most.
Thinking about buying Supermicro boards (maybe 2nd hand). Afaik the X9 line is also using Java.
Read somewhere that mounting remotely does not work with html?
Is the usable nowadays? Is this based on a Asrock or Supermicro "line" (aka: X10, X11)
Requirements:
Requirements:
- Browser access (Linux/Windows)
- Remote mount
- basis stuff (on/off. Read console output)
- dedicated port (no multiplex on server interface)
- It just works
