Hi All,
I installed FreeNas 8.0 on a Intel C2Duo with 4GB RAM on a 4GB USB FLASH Drive.
1 x 500GB
2 x 2TB Disks
I created a ZFS Pool with no redundancy to get the maximum storage.
It was running fine and I upgraded to FreeNas 8.02 Beta2 - all was good
Until a few days ago when intermittently the share will be inaccessible, web interface inaccessible - the support person powered down the machine, took the usb flash out and inserted into a different USB slot on the same machine and powered ON. All was good again
Now since this morning - no matter what we do - it won't come up and it has 750GB data on it.
1 - What are the steps to recover ?
2 - Shall I re-install freenas on the same usb flash and then restore the config?
3 - Can we install a newer version like 8.0.1 Beta4 or it has to be the same version ?
Will be grateful for your prompt response
Kind Regards
NasFree
1 x 500GB
2 x 2TB Disks
Kind Regards
NasFree
