Register for the iXsystems Community to get an ad-free experience
SOLVED UrBackup fails to install in a clean Jail (v11.0-U2)
Hazimil
Hi All,
I'm trying to install UrBackup in a fresh Jail, on v11.0-U2, and am following the instructions laid out at: https://www.urbackup.org/freenasserverinstall.html, i.e.
pkg update
pkg install cryptopp
curl -O https://hndl.urbackup.org/Server/2.1.19/urbackup-server-2.1.19.tar.gz
tar xf urbackup-server-2.1.19.tar.gz
cd urbackup-server-2.1.19
./configure
make install -j4
But, I'm getting some errors and it fails to install after I use the make install -j4 command:
chown urbackup:urbackup "/usr/local/share/urbackup"
chown: urbackup: illegal group name
*** [install-data-local] Error code 1
make[2]: stopped in /urbackup-server-2.1.19
--- install-exec-local ---
pw useradd urbackup -q -g urbackup -d "/usr/local/var/urbackup" -m -s /usr/bin/false || true
chown urbackup:urbackup "/usr/local/var/urbackup"
1 error
*** [install-am] Error code 2
make[1]: stopped in /urbackup-server-2.1.19
1 error
*** [install-recursive] Error code 1
make: stopped in /urbackup-server-2.1.19
1 error
Anyone got any ideas?
Yours
Jonathan
Jailer
Not strong, but bad
Did you try updating the jail before installing? pkg upgrade
Hazimil
This would suggest the user or group does not exist.
That's what I though, yet I thought I check to see if they existed, and when I tried to adduser (for urbackup) or pw addgroup (for urbackup), I get told that they already exist..... So the script must have created them.
Yep, ran all commands as per the list in my opening post.
Yours
Jonathan
Hazimil
So, I tried something different this time. After I ran pkg update and before I ran pkg install cryptopp, I did the following:
pw addgroup urbackup
(copying the useradd from the error output above)
Then I continued with the install, this time I don't get any errors, but I'm unable to connect to it via 192.168.x.xxx:55414
Bah!
Yours
Jonathan
Hazimil
Ahh ha! Fixed it!
It helps if you start the service ( /usr/local/bin/urbackupsrv run -d -g 104857600 -u root) :)
Yours
Jonathan
