UPS: how to know if it is compatible with TrueNAS CORE?
zamana
Hi!
My current UPS is dying (so I think...) and I'm planning to buy a new one.
I'm considering a Brazilian brand (SMS) and there is just one driver available (highlighted in RED) in TrueNAS currently:
And the technical manual says nothing about drivers...
The question is: how can I know, before actually buying, that the UPS has a driver compatible with TrueNAS CORE?
I know I can always ask the company, but I doubt that they know anything about TrueNAS, FreeBSD and UNIX in general...
Thanks.
Regards.
  • DOVI049141.pdf
TrueNAS uses NUT. You can check the HCL at the developers site, but even if your exact model is not listed most manufacturers use the same driver/protocol for the majority of their models.
Even though the model in the PDF you attached has both a USB and serial interface, looks like only the serial option is supported
zamana
Hi!
Yes, I check this page:
I'm trying to contact the SMS company in order to know if this UPS is in this "Manager III" model category...
Thanks.
Regards.
Patrick M. Hausen
I recommend staying away from anything using the USB-HID interface. NUT is a rather Linux centric project and the implementation of USB in FreeBSD is sufficiently different to cause compatibility problems. An UPS with a network interface and SNMP has a way greater chance of working out of the box.
zamana
Got it.
It has this as an optional component:
6.3. SMS NET ADAPTER II (Adaptador de rede SNMP/HTTP)
It's a network adapter that allows it to be managed without the need of a computer...
Would this resolve the driver compatibility issue?
Got it.
I don't think TrueNAS supports SNMP UPS monitoring
