I have a problem with my UPS.
When I came home today, the UPS was giving a constant beeping noise and power was off.
Turns out, there is a problem with the power outlet on my balcony and during the rain today the residual-current circuit breaker went off. Not a big problem, I switched power back on and restarted the UPS.
Then I checked my FreeNAS logs:
/var/log/ups.log:
last
Well, there seems to be no shutdown. Not good.
I checked the battery and it was at 97%, so I just plugged the UPS out and waited.
It started its usual beeping on power loss (~every 20sec or so)
After some time (maybe 1 or 2 min) the UPS just cut the power and started to give off a constant annoying beeping noise.
After booting I checked again and the battery was still at 94%. So I just disconnected the UPS USB connection and removed power. Everything worked fine for 10min. The UPS was still at 81% battery.
So something is wrong in my FreeNAS configuration. It seems the server is shutting down the UPS without shutting down the system first or maybe some waiting time sent to the UPS is not working?
The UPS is a PowerWalker VI 850 SE and is configured with this settings:
upsc ups gives:
What is wrong with my setup?
Bonus question: Is there a way to configure the UPS to not constantly beep when off? that's pretty annoying. I still want to keep the beeps every 20sec or so when running on battery.
/var/log/ups.log:
20150520 145923 100 233.0 14 [OL] 25.0 50.5 20150520 150423 100 230.0 13 [OL] 25.0 50.3 20150520 150923 63 0.0 23 [OB] 25.0 50.1 20150520 190815 NA NA NA [WAIT] NA NA 20150520 191314 97 230.0 13 [OL] 25.0 50.3 20150520 191815 97 230.0 13 [OL] 25.0 50.3
last
josef pts/1 10.24.42.1 Wed May 20 19:13 - 19:19 (00:06) boot time Wed May 20 19:12 josef pts/1 10.24.42.81 Mon May 18 18:53 - 21:10 (02:17) boot time Fri May 15 23:32
upsc ups gives:
battery.charge: 93 battery.voltage: 13.30 battery.voltage.high: 13.5 battery.voltage.low: 10.5 battery.voltage.nominal: 12.0 device.type: ups driver.flag.novendor: enabled driver.name: blazer_usb driver.parameter.pollinterval: 15 driver.parameter.port: /dev/ugen0.1 driver.version: 2.7.2 driver.version.internal: 0.11 input.current.nominal: 3.0 input.frequency: 50.3 input.frequency.nominal: 50 input.voltage: 231.4 input.voltage.fault: 231.4 input.voltage.nominal: 230 output.voltage: 231.4 ups.beeper.status: enabled ups.delay.shutdown: 30 ups.delay.start: 180 ups.load: 13 ups.productid: 5161 ups.status: OL ups.temperature: 25.0 ups.type: offline / line interactive ups.vendorid: 0665
