Upgrading pool bug Core to Scale.
K.J
After updating from core to scale I got the following message (see pictures): warning new ZFS, upgrading pool.
The tap sheet: upgrading pool is not visible when I press the cogwheel (see photos).
What is now the best option to upgrade the pool, it is the system dataset pool.
Arwen
In general, you want to wait a few weeks or so. While SCALE is officially released, version 1.0 of any software can have hidden gotchas.
The pool versions between Core and SCALE may not be synchronized. So, if you update the pool version without a specific need, you may be locked out of going back to the version of Core you came from.
This same applies when updating inside the same OS, like Core 12.1 -> 12.2. If their is a new ZFS pool version, you may want to wait til just before you update to 12.3. That way you always can go back 1 OS version. Just saying...
K.J
@Arwen
Finally this weekend decided to do a clean install of scale to get rid of all the messages.
And that worked :smile:
I recommend it to everyone instead of upgrading from Core to scale.
