aahzinfotech
- Jul 13, 2021
We've been using FreeNAS for several years and upgraded to TrueNAS a couple versions ago. Under FreeNAS, I had set up snapshots for a specific folder and it was set-and-forget. We didn't have any problems. We are at version TrueNAS-12.0-U4.
When I went to check out the snapshot history yesterday, I noticed that the only pool with snapshots was the iocage pool. I know I had created another pool previously, but the Pool Manager only shows the following: > pool > iocage and nothing else. I was hoping to get snapshots of > pool > second.folder. Yikes!
A bit of forum searching led me to realize that I need to create a new pool, but am quite unsure how to do that since my attempt to do so shows no available disks. And I'm afraid that to do so I may have to restart from scratch if I am determined to have snapshots.
This being the case, what or how would you recommend I go about getting this set back up?
Version: TrueNAS 12.0 U4
PowerEdge T310 with Intel Xeon CPU X3430
4 * 8GB RAM 1333 MHz DDR3
5 * ATA HGST HUH721010AL with IBM M1015 and 1 * 256GB SSD (boot)
