upgradge to FNS 8 lost 2.7 TB data....need help
kajisan
i have a raid5 with 4*1T disk. it's work fine in FNS 7. in my FNS backup config file.
<disks>
<disk>
<uuid>1be6625c-7451-4dcd-b30c-0a720df93bd0</uuid>
<name>aacdu0</name>
<devicespecialfile>/dev/aacdu0</devicespecialfile>
<harddiskstandby>5</harddiskstandby>
<acoustic>0</acoustic>
<apm>0</apm>
<transfermode>auto</transfermode>
<type>RAID</type>
<desc>raid5</desc>
<size>2860022MB</size>
<smart>
<enable/>
<extraoptions/>
</smart>
<fstype>ufsgpt</fstype>
</disk>
</disks>
this is FNS 7 mount config
<mounts>
<mount>
<uuid>817e4288-1817-4ee4-9443-9e64766b451c</uuid>
<type>disk</type>
<mdisk>/dev/aacdu0</mdisk>
<partition>p1</partition>
<fstype>ufs</fstype>
<devicespecialfile>/dev/aacdu0p1</devicespecialfile>
<sharename>r5</sharename>
<desc/>
<accessrestrictions>
<owner>root</owner>
<group>wheel</group>
<mode>0777</mode>
</accessrestrictions>
</mount>
</mounts>
when i installed FNS 8,in web gui i chose import volume.
than chose aacd0p1 and UFS type. chick import.
then a long time have no effect.i close my brower and try again. again ..again..
in this time .i found fsck_ufs is running......:(... so i think need long time is normal..
so i got sleep.
when i wakeup..
they have a log of error message. so i reboot it and try again..
it's say
The selected disks were not verified for this import rules.
i think maybe something wrong ,so i reinstall FNS7 ...and restore my config.
but......
it's wrong!!!!!
it's say my disk miss...
so when i check it. /dev/aacd0u change to /dev/aacd0p1 ..i don't know why it happend.
i try fsck and fsck_ufs fsck_ffs
freenas# fsck /dev/aacd0
fsck: Could not determine filesystem type
freenas# fsck_ffs /dev/aacd0
** /dev/aacd0
Cannot find file system superblock
ioctl (GCINFO): Inappropriate ioctl for device
fsck_ffs: /dev/aacd0: can't read disk label
freenas# fsck_ufs /dev/aacd0
** /dev/aacd0
fsck_ufs: /dev/aacd0: can't read disk label
i try mount..
freenas# mount -r /dev/aacd0p1 /mnt/r5
mount: /dev/aacd0p1 : Invalid argument
so i realy need help to find my data.
my fstab and my mount
freenas# cat /etc/fstab
/dev/ufs/FreeNASs1a / ufs ro 1 1
/dev/ufs/FreeNASs3 /cfg ufs rw,noauto 2 2
/dev/ufs/FreeNASs4 /data ufs rw 2 2
freenas# mount
/dev/ufs/FreeNASs1a on / (ufs, local, read-only, soft-updates)
devfs on /dev (devfs, local, multilabel)
/dev/md0 on /etc (ufs, local)
/dev/md1 on /mnt (ufs, local)
/dev/md2 on /var (ufs, local)
/dev/ufs/FreeNASs4 on /data (ufs, local, soft-updates)
freenas# ls -l /dev/aacd0*
crw-r----- 1 root operator 0, 81 Aug 17 19:03 /dev/aacd0
crw-r----- 1 root operator 0, 82 Aug 18 17:38 /dev/aacd0p1
freenas#
my dmesg is
Copyright (c) 1992-2011 The FreeBSD Project.
Copyright (c) 1979, 1980, 1983, 1986, 1988, 1989, 1991, 1992, 1993, 1994
The Regents of the University of California. All rights reserved.
FreeBSD is a registered trademark of The FreeBSD Foundation.
FreeBSD 8.2-RELEASE-p1 #2: Sat Apr 30 12:10:51 PDT 2011
jpaetzel@servant.iXsystems.com:/usr/home/jpaetzel/freenas/obj.i386/i386/usr/ home/jpaetzel/freenas/FreeBSD/src/sys/FREENAS.i386 i386
Timecounter "i8254" frequency 1193182 Hz quality 0
CPU: Intel(R) XEON(TM) CPU 2.40GHz (2392.25-MHz 686-class CPU)
Origin = "GenuineIntel" Id = 0xf24 Family = f Model = 2 Stepping = 4
Features=0x3febfbff
real memory = 2147483648 (2048 MB)
avail memory = 2086154240 (1989 MB)
ACPI APIC Table:
FreeBSD/SMP: Multiprocessor System Detected: 4 CPUs
FreeBSD/SMP: 4 package(s) x 1 core(s)
cpu0 (BSP): APIC ID: 0
cpu1 (AP): APIC ID: 1
cpu2 (AP): APIC ID: 6
cpu3 (AP): APIC ID: 7
ioapic0 irqs 0-23 on motherboard
ioapic1 irqs 24-47 on motherboard
ioapic2 irqs 48-71 on motherboard
kbd1 at kbdmux0
netsmb_dev: loaded
cryptosoft0: on motherboard
acpi0: on motherboard
acpi0: [ITHREAD]
acpi0: Power Button (fixed)
Timecounter "ACPI-fast" frequency 3579545 Hz quality 1000
acpi_timer0: <24-bit timer at 3.579545MHz> port 0x1008-0x100b on acpi0
cpu0: on acpi0
cpu1: on acpi0
cpu2: on acpi0
cpu3: on acpi0
pcib0: port 0xcf8-0xcff on acpi0
pci0: on pcib0
pci0: at device 0.1 (no driver attached)
pcib1: at device 2.0 on pci0
pci1: on pcib1
pcib2: at device 29.0 on pci1
pci2: on pcib2
pcib3: at device 31.0 on pci1
pci3: on pcib3
pcib4: at device 1.0 on pci3
pci4: on pcib4
aac0: mem 0xfc200000-0xfc3fffff irq 50 at device 14.0 on pci4
aac0: Enable Raw I/O
aac0: Enable 64-bit array
aac0: New comm. interface enabled
aac0: [ITHREAD]
aac0: Adaptec 4800SAS, aac driver 2.1.9-1
aacp0: on aac0
aacp1: on aac0
aacp2: on aac0
uhci0: port 0x7000-0x701f irq 16 at device 29.0 on pci0
uhci0: [ITHREAD]
usbus0: on uhci0
uhci1: port 0x7020-0x703f irq 19 at device 29.1 on pci0
uhci1: [ITHREAD]
usbus1: on uhci1
pcib5: at device 30.0 on pci0
pci5: on pcib5
vgapci0: port 0x8000-0x80ff mem 0xfd000000-0xfdffffff,0 xfc400000-0xfc400fff irq 21 at device 3.0 on pci5
fxp0: port 0x8400-0x843f mem 0xfc401000-0xfc401ff f,0xfc420000-0xfc43ffff irq 20 at device 4.0 on pci5
miibus0: on fxp0
inphy0: PHY 1 on miibus0
inphy0: 10baseT, 10baseT-FDX, 100baseTX, 100baseTX-FDX, auto, auto-flow
fxp0: Ethernet address: 00:02:b3:b0:cd:71
fxp0: [ITHREAD]
fxp1: port 0x8440-0x847f mem 0xfc402000-0xfc402ff f,0xfc440000-0xfc45ffff irq 23 at device 5.0 on pci5
miibus1: on fxp1
inphy1: PHY 1 on miibus1
inphy1: 10baseT, 10baseT-FDX, 100baseTX, 100baseTX-FDX, auto, auto-flow
fxp1: Ethernet address: 00:02:b3:b0:cc:90
fxp1: [ITHREAD]
isab0: at device 31.0 on pci0
isa0: on isab0
atapci0: port 0x1f0-0x1f7,0x3f6,0x170-0x177,0x37 6,0x7040-0x704f at device 31.1 on pci0
ata0: on atapci0
ata0: [ITHREAD]
ata1: on atapci0
ata1: [ITHREAD]
pci0: at device 31.3 (no driver attached)
acpi_button0: on acpi0
atrtc0: port 0x70-0x71 irq 8 on acpi0
atkbdc0: port 0x60,0x64 irq 1 on acpi0
atkbd0: irq 1 on atkbdc0
kbd0 at atkbd0
atkbd0: [GIANT-LOCKED]
atkbd0: [ITHREAD]
fdc0: port 0x3f0-0x3f3,0x3f4-0x3f5,0x3f7 irq 6 drq 2 o n acpi0
fdc0: does not respond
device_attach: fdc0 attach returned 6
uart0: <16550 or compatible> port 0x3f8-0x3ff irq 4 flags 0x10 on acpi0
uart0: [FILTER]
uart1: <16550 or compatible> port 0x2f8-0x2ff irq 3 on acpi0
uart1: [FILTER]
ppc0: port 0x378-0x37f,0x778-0x77b irq 7 drq 3 on acpi0
ppc0: SMC-like chipset (ECP/EPP/PS2/NIBBLE) in COMPATIBLE mode
ppc0: FIFO with 16/16/9 bytes threshold
ppc0: [ITHREAD]
ppbus0: on ppc0
lpt0: on ppbus0
lpt0: [ITHREAD]
lpt0: Interrupt-driven port
ppi0: on ppbus0
pmtimer0 on isa0
orm0: at iomem 0xc0000-0xc7fff,0xc8000-0xcd7ff,0xe3800-0xe3fff pnpid ORM0000 on isa0
sc0: at flags 0x100 on isa0
sc0: VGA <16 virtual consoles, flags=0x300>
vga0: at port 0x3c0-0x3df iomem 0xa0000-0xbffff on isa0
p4tcc0: on cpu0
p4tcc1: on cpu1
p4tcc2: on cpu2
p4tcc3: on cpu3
Timecounters tick every 1.000 msec
aacd0: on aac0
aacd0: 2860022MB (5857325056 sectors)
usbus0: 12Mbps Full Speed USB v1.0
usbus1: 12Mbps Full Speed USB v1.0
ugen0.1: at usbus0
uhub0: on usbus0
ata0: DMA limited to UDMA33, controller found non-ATA66 cable
ugen1.1: at usbus1
uhub1: on usbus1
uhub0: 2 ports with 2 removable, self powered
uhub1: 2 ports with 2 removable, self powered
cd0 at ata1 bus 0 scbus4 target 0 lun 0
cd0: < TECLAST DHB16X2 BG21> Removable CD-ROM SCSI-0 device
cd0: 33.300MB/s transfers (UDMA2, ATAPI 12bytes, PIO 65534bytes)
cd0: Attempt to query device size failed: NOT READY, Medium not present - tray c losed
ada0 at ata0 bus 0 scbus3 target 0 lun 0
ada0: ATA-0 device
ada0: 33.300MB/s transfers (UDMA2, PIO 512bytes)
ada0: 3831MB (7847280 512 byte sectors: 16H 63S/T 7785C)
pass0 at aacp0 bus 0 scbus0 target 4 lun 0
pass0: Fixed Uninstalled SCSI-5 device
pass0: 3.300MB/s transfers
pass1 at aacp0 bus 0 scbus0 target 5 lun 0
pass1: Fixed Uninstalled SCSI-5 device
pass1: 3.300MB/s transfers
pass2 at aacp0 bus 0 scbus0 target 6 lun 0
pass2: Fixed Uninstalled SCSI-5 device
pass2: 3.300MB/s transfers
pass3 at aacp0 bus 0 scbus0 target 7 lun 0
pass3: Fixed Uninstalled SCSI-5 device
pass3: 3.300MB/s transfers
SMP: AP CPU #1 Launched!
SMP: AP CPU #2 Launched!
SMP: AP CPU #3 Launched!
Trying to mount root from ufs:/dev/ufs/FreeNASs1a
WARNING: /data was not properly dismounted
fxp1: link state changed to UP
fuse4bsd: version 0.3.9-pre1, FUSE ABI 7.8
ZFS NOTICE: Prefetch is disabled by default on i386 -- to enable,
add "vfs.zfs.prefetch_disable=0" to /boot/loader.conf.
ZFS WARNING: Recommended minimum kmem_size is 512MB; expect unstable behavior.
Consider tuning vm.kmem_size and vm.kmem_size_max
in /boot/loader.conf.
ZFS filesystem version 4
ZFS storage pool version 15
