Running FreeNAS-8.0.4-BETA2-x64 (10134)
I have two 1TB Seagate SATA drives Model: ST31000528AS
I am following what i think are the correct steps to create a Raid1 mirror
1. Go to Create Volume
2. give it a name such as Fnas804
3. Select ada0 & ada1 (my SATA drives, & these show up in the list of available drives)
4. Select either UFS or ZFS (doesn't matter ehich as both option give me the same error)
5. Select "mirrior"
6. Click "Add Volume"
and I get the following error:
"MiddlewareError Volume creation failed geom Can't store metadata Operation not permitted"
These are the log entries:
Feb 26 11:25:16 freenas freenas[1788]: Executing: swapoff -a
Feb 26 11:25:16 freenas freenas[1788]: Executing: geom disk list ada0 | grep 'Stripesize: 4096'
Feb 26 11:25:16 freenas freenas[1788]: Executing: geom disk list ada0 | grep 'Sectorsize: 512'
Feb 26 11:25:16 freenas freenas[1788]: Executing: dd if=/dev/zero of=/dev/ada0 bs=1m count=1
Feb 26 11:25:16 freenas freenas: dd: /dev/ada0: Operation not permitted
Feb 26 11:25:16 freenas freenas[1788]: Executing: dd if=/dev/zero of=/dev/ada0 bs=1m oseek=`diskinfo ada0 | awk '{print int($3 / (1024*1024)) - 4;}'`
Feb 26 11:25:16 freenas freenas[1788]: Popen()ing: gpart create -s gpt /dev/ada0
Feb 26 11:30:16 freenas freenas[1788]: Executing: geom mirror load
Feb 26 11:30:16 freenas freenas: geom: Command 'load' not available.
Feb 26 11:30:16 freenas freenas[1788]: Popen()ing: geom mirror label fffmirror /dev/ada0 /dev/ada1
Feb 26 11:30:42 freenas freenas[1788]: Executing: geom mirror load
Feb 26 11:30:42 freenas freenas: geom: Command 'load' not available.
Feb 26 11:30:42 freenas freenas[1788]: Popen()ing: geom mirror label ffmirror /dev/ada0 /dev/ada1
If run the command:
sysctl kern.geom.debugflags=0x10
Then I get:
Volume successfully created, however when viewing the volume, the see the following issues:
Used: none(Error)
Available: Error getting available space
Size: Error getting total space
Status: Unknown
So, did I miss a step, or is there a bigger issue here? I have zeroed out both entire drives using dd.
Note: I might could get 4GB of RAM in this PC, but I would have to research it.
Dmesg below:
Copyright (c) 1992-2011 The FreeBSD Project.
Copyright (c) 1979, 1980, 1983, 1986, 1988, 1989, 1991, 1992, 1993, 1994
The Regents of the University of California. All rights reserved.
FreeBSD is a registered trademark of The FreeBSD Foundation.
FreeBSD 8.2-RELEASE-p6 #0: Mon Feb 13 20:14:52 PST 2012
root@build.ixsystems.com:/build/home/gcooper/e2e-bld.MWzoAU86/obj.amd64/build/home/gcooper/e2e-bld.MWzoAU86/FreeBSD/src/sys/FREENAS.amd64 amd64
Timecounter "i8254" frequency 1193182 Hz quality 0
CPU: AMD Athlon(tm) 64 Processor 3200+ (1994.21-MHz K8-class CPU)
Origin = "AuthenticAMD" Id = 0x20ff2 Family = f Model = 2f Stepping = 2
Features=0x78bfbff<FPU,VME,DE,PSE,TSC,MSR,PAE,MCE,CX8,APIC,SEP,MTRR,PGE,MCA,CMOV,PAT,PSE36,CLFLUSH,MMX,FXSR,SSE,SSE2>
Features2=0x1<SSE3>
AMD Features=0xe2500800<SYSCALL,NX,MMX+,FFXSR,LM,3DNow!+,3DNow!>
AMD Features2=0x1<LAHF>
real memory = 2147483648 (2048 MB)
avail memory = 1989570560 (1897 MB)
ACPI APIC Table: <HP AWRDACPI>
ioapic0 <Version 2.1> irqs 0-23 on motherboard
kbd1 at kbdmux0
cryptosoft0: <software crypto> on motherboard
acpi0: <HP AWRDACPI> on motherboard
acpi0: Overriding SCI Interrupt from IRQ 9 to IRQ 21
acpi0: [ITHREAD]
acpi0: Power Button (fixed)
acpi0: reservation of 0, a0000 (3) failed
acpi0: reservation of 100000, 7bdf0000 (3) failed
Timecounter "ACPI-fast" frequency 3579545 Hz quality 1000
acpi_timer0: <32-bit timer at 3.579545MHz> port 0x4008-0x400b on acpi0
cpu0: <ACPI CPU> on acpi0
acpi_button0: <Power Button> on acpi0
pcib0: <ACPI Host-PCI bridge> port 0xcf8-0xcff on acpi0
pci0: <ACPI PCI bus> on pcib0
pcib1: <ACPI PCI-PCI bridge> at device 1.0 on pci0
pci1: <ACPI PCI bus> on pcib1
vgapci0: <VGA-compatible display> port 0xcc00-0xccff mem 0xd0000000-0xd7ffffff,0xfdaf0000-0xfdafffff irq 17 at device 5.0 on pci1
vgapci1: <VGA-compatible display> mem 0xc8000000-0xcfffffff,0xfdae0000-0xfdaeffff at device 5.1 on pci1
pcib2: <PCI-PCI bridge> at device 5.0 on pci0
pci2: <PCI bus> on pcib2
bge0: <Broadcom NetXtreme Gigabit Ethernet Controller, ASIC rev. 0x004200> mem 0xfdef0000-0xfdefffff irq 17 at device 0.0 on pci2
bge0: CHIP ID 0x00004200; ASIC REV 0x04; CHIP REV 0x42; PCI-E
miibus0: <MII bus> on bge0
brgphy0: <BCM5750 10/100/1000baseTX PHY> PHY 1 on miibus0
brgphy0: 10baseT, 10baseT-FDX, 100baseTX, 100baseTX-FDX, 1000baseT, 1000baseT-master, 1000baseT-FDX, 1000baseT-FDX-master, auto, auto-flow
bge0: Ethernet address: 00:19:db:2d:dd:98
bge0: [ITHREAD]
atapci0: <ATI IXP400 SATA150 controller> port 0xfc00-0xfc07,0xf800-0xf803,0xf400-0xf407,0xf000-0xf003,0xec00-0xec0f mem 0xfe02f000-0xfe02f1ff irq 23 at device 18.0 on pci0
atapci0: [ITHREAD]
ata2: <ATA channel 0> on atapci0
ata2: [ITHREAD]
ata3: <ATA channel 1> on atapci0
ata3: [ITHREAD]
ohci0: <ATI SB400 USB Controller> mem 0xfe02e000-0xfe02efff at device 19.0 on pci0
ohci0: [ITHREAD]
usbus0: <ATI SB400 USB Controller> on ohci0
ohci1: <ATI SB400 USB Controller> mem 0xfe02d000-0xfe02dfff at device 19.1 on pci0
ohci1: [ITHREAD]
usbus1: <ATI SB400 USB Controller> on ohci1
ehci0: <ATI SB400 USB 2.0 controller> mem 0xfe02c000-0xfe02cfff at device 19.2 on pci0
ehci0: [ITHREAD]
usbus2: EHCI version 1.0
usbus2: <ATI SB400 USB 2.0 controller> on ehci0
pci0: <serial bus, SMBus> at device 20.0 (no driver attached)
atapci1: <ATI IXP400 UDMA133 controller> port 0x1f0-0x1f7,0x3f6,0x170-0x177,0x376,0xe400-0xe40f at device 20.1 on pci0
ata0: <ATA channel 0> on atapci1
ata0: [ITHREAD]
ata1: <ATA channel 1> on atapci1
ata1: [ITHREAD]
isab0: <PCI-ISA bridge> at device 20.3 on pci0
isa0: <ISA bus> on isab0
pcib3: <ACPI PCI-PCI bridge> at device 20.4 on pci0
pci3: <ACPI PCI bus> on pcib3
rl0: <RealTek 8139 10/100BaseTX> port 0xbc00-0xbcff mem 0xfddff000-0xfddff0ff irq 22 at device 11.0 on pci3
miibus1: <MII bus> on rl0
rlphy0: <RealTek internal media interface> PHY 0 on miibus1
rlphy0: 10baseT, 10baseT-FDX, 100baseTX, 100baseTX-FDX, auto
rl0: Ethernet address: 00:14:d1:1a:e6:a9
rl0: [ITHREAD]
amdtemp0: <AMD K8 Thermal Sensors> on hostb4
acpi_tz0: <Thermal Zone> on acpi0
atkbdc0: <Keyboard controller (i8042)> port 0x60,0x64 irq 1 on acpi0
atkbd0: <AT Keyboard> irq 1 on atkbdc0
kbd0 at atkbd0
atkbd0: [GIANT-LOCKED]
atkbd0: [ITHREAD]
psm0: <PS/2 Mouse> irq 12 on atkbdc0
psm0: [GIANT-LOCKED]
psm0: [ITHREAD]
psm0: model IntelliMouse, device ID 3
atrtc0: <AT realtime clock> port 0x70-0x73 irq 8 on acpi0
orm0: <ISA Option ROMs> at iomem 0xc0000-0xcbfff,0xcc000-0xcffff on isa0
sc0: <System console> at flags 0x100 on isa0
sc0: VGA <16 virtual consoles, flags=0x300>
vga0: <Generic ISA VGA> at port 0x3c0-0x3df iomem 0xa0000-0xbffff on isa0
ppc0: cannot reserve I/O port range
powernow0: <Cool`n'Quiet K8> on cpu0
fuse4bsd: version 0.3.9-pre1, FUSE ABI 7.8
Timecounter "TSC" frequency 1994211366 Hz quality 800
Timecounters tick every 1.000 msec
usbus0: 12Mbps Full Speed USB v1.0
usbus1: 12Mbps Full Speed USB v1.0
usbus2: 480Mbps High Speed USB v2.0
ugen0.1: <ATI> at usbus0
uhub0: <ATI OHCI root HUB, class 9/0, rev 1.00/1.00, addr 1> on usbus0
ugen1.1: <ATI> at usbus1
uhub1: <ATI OHCI root HUB, class 9/0, rev 1.00/1.00, addr 1> on usbus1
ugen2.1: <ATI> at usbus2
uhub2: <ATI EHCI root HUB, class 9/0, rev 2.00/1.00, addr 1> on usbus2
uhub0: 4 ports with 4 removable, self powered
uhub1: 4 ports with 4 removable, self powered
uhub2: 8 ports with 8 removable, self powered
ugen2.2: <vendor 0x13fe> at usbus2
umass0: <vendor 0x13fe Patriot Memory, class 0/0, rev 2.00/1.00, addr 2> on usbus2
ada0 at ata2 bus 0 scbus0 target 0 lun 0cd0 at ata0 bus 0 scbus2 target 0 lun 0
cd0: <TSSTcorp CDW/DVD TS-H492C CB06> Removable CD-ROM SCSI-0 device
cd0: 44.400MB/s transfers (UDMA3, ATAPI 12bytes, PIO 65534bytes)
cd0: Attempt to query device size failed: NOT READY, Medium not present - tray closed
ada0: <ST31000528AS CC3E> ATA-8 SATA 2.x deviceda0 at umass-sim0 bus 0 scbus4 target 0 lun 0
da0: < Patriot Memory PMAP> Removable Direct Access SCSI-0 device
da0: 40.000MB/s transfers
da0: 3825MB (7833600 512 byte sectors: 255H 63S/T 487C)
ada0: 133.000MB/s transfers (UDMA6, PIO 8192bytes)
ada0: 953869MB (1953525168 512 byte sectors: 16H 63S/T 16383C)
ada1 at ata3 bus 0 scbus1 target 0 lun 0
ada1: <ST31000528AS CC3E> ATA-8 SATA 2.x device
ada1: 133.000MB/s transfers (UDMA6, PIO 8192bytes)
ada1: 953869MB (1953525168 512 byte sectors: 16H 63S/T 16383C)
GEOM: da0s1: geometry does not match label (16h,63s != 255h,63s).
GEOM_MIRROR: Device mirror/FRaid launched (2/2).
GEOM: mirror/FRaid: corrupt or invalid GPT detected.
GEOM: mirror/FRaid: GPT rejected -- may not be recoverable.
Trying to mount root from ufs:/dev/ufs/FreeNASs1a
ZFS NOTICE: Prefetch is disabled by default if less than 4GB of RAM is present;
to enable, add "vfs.zfs.prefetch_disable=0" to /boot/loader.conf.
ZFS filesystem version 4
ZFS storage pool version 15
5. Select "mirrior"
If run the command:
Then I get:
Used: none(Error)
Status: Unknown
Dmesg below:
Features2=0x1<SSE3>
kbd1 at kbdmux0
acpi0: [ITHREAD]
bge0: [ITHREAD]
atapci0: [ITHREAD]
ata2: [ITHREAD]
ata3: [ITHREAD]
ohci0: [ITHREAD]
ohci1: [ITHREAD]
ehci0: [ITHREAD]
ata0: [ITHREAD]
ata1: [ITHREAD]
rl0: [ITHREAD]
kbd0 at atkbd0
atkbd0: [ITHREAD]
psm0: [ITHREAD]
