danjb
- Aug 2, 2014
A few weeks ago I upgraded from a FreeNAS 11.3 to a TrueNAS-12.0-STABLE system. All seems good so far, except for VM's. I decided to experiment creating a VM shortly after upgrading, and it worked. I disabled the VM and left it. Today I went back to create a VM for real, but first decided to delete the single experimental VM. When I tried to delete the old VM, I get the error: Error creating VM. [EFAULT] Failed to connect to libvirt. Here is the stack trace:
I tried this in a different browser as well to make sure it wasn't cache issues. I then decided to just ignore the experiment VM, and create the one I wanted. Unfortunately, when I do that, I get the exact same error, but where the stack trace above says delete the create stack trace says create.
Any idea how to get past this? Can I deal with VM's from the command line instead of the GUI in case there's something wrong with the GUI holding this up?
File "/usr/local/lib/python3.8/site-packages/middlewared/main.py", line 137, in call_method
result = await self.middleware._call(message['method'], serviceobj, methodobj, params, app=self,
File "/usr/local/lib/python3.8/site-packages/middlewared/main.py", line 1191, in _call
File "/usr/local/lib/python3.8/site-packages/middlewared/service.py", line 471, in delete
rv = await self.middleware._call(
File "/usr/local/lib/python3.8/site-packages/middlewared/schema.py", line 973, in nf
File "/usr/local/lib/python3.8/site-packages/middlewared/plugins/vm.py", line 1448, in do_delete
await self.middleware.call('vm.ensure_libvirt_connection')
File "/usr/local/lib/python3.8/site-packages/middlewared/main.py", line 1233, in call
return await self._call(
File "/usr/local/lib/python3.8/site-packages/middlewared/main.py", line 1202, in _call
File "/usr/local/lib/python3.8/site-packages/middlewared/main.py", line 1106, in run_in_executor
File "/usr/local/lib/python3.8/site-packages/middlewared/utils/io_thread_pool_executor.py", line 25, in run
File "/usr/local/lib/python3.8/site-packages/middlewared/plugins/vm.py", line 1494, in ensure_libvirt_connection
raise CallError('Failed to connect to libvirt')
middlewared.service_exception.CallError: [EFAULT] Failed to connect to libvirt
