If it fails on successive reboots, please report a bug with full hardware configuration.
Has anyone else seen this?
I've had that problem too, every time I've tried to upgrade past .4
To the RC, nightly, clean configs, nothing has worked. Always "middleware not running"
Able to create net new system- was not able to update it from an older install .iso- started over with 22.12 and am fine. The issue on the existing server is exactly as above- missing column in config database (system_settings.stg_ds_auth).Same here. Cannot update past 22.02.4, cannot delete the broken 22.12.0 environment.
Trying to install 22.12.0 on a new server with very different hardware as a net new (not migrating, adding for redundancy) environment - will report if I can get that one up.
I tried the update via the UI as well as burning the full install image to a USB drive and doing a full upgrade which states everything worked ok and had no errors with the database migration step.
Should I try an overwrite install and try to apply my config settings from the backup file?
Dec 28 13:06:28 freenas middlewared[70564]: File "/usr/lib/python3/dist-packages/middlewared/plugins/zettarepl.py", line 147, in __call__ Dec 28 13:06:28 freenas middlewared[70564]: move_to_root_cgroups(os.getpid()) Dec 28 13:06:28 freenas middlewared[70564]: File "/usr/lib/python3/dist-packages/middlewared/utils/cgroups.py", line 13, in move_to_root_cgroups Dec 28 13:06:28 freenas middlewared[70564]: with open(f"/sys/fs/cgroup/{new_name}/cgroup.procs", "w") as f2: Dec 28 13:06:28 freenas middlewared[70564]: FileNotFoundError: [Errno 2] No such file or directory: '/sys/fs/cgroup/unified/cgroup.procs' Dec 28 13:06:29 freenas middlewared[70567]: Process zettarepl: Dec 28 13:06:29 freenas middlewared[70567]: Traceback (most recent call last): Dec 28 13:06:29 freenas middlewared[70567]: File "/usr/lib/python3.9/multiprocessing/process.py", line 315, in _bootstrap Dec 28 13:06:29 freenas middlewared[70567]: self.run() Dec 28 13:06:29 freenas middlewared[70567]: File "/usr/lib/python3.9/multiprocessing/process.py", line 108, in run Dec 28 13:06:29 freenas middlewared[70567]: self._target(*self._args, **self._kwargs) Dec 28 13:06:29 freenas middlewared[70567]: File "/usr/lib/python3/dist-packages/middlewared/plugins/zettarepl.py", line 147, in __call__ Dec 28 13:06:29 freenas middlewared[70567]: move_to_root_cgroups(os.getpid()) Dec 28 13:06:29 freenas middlewared[70567]: File "/usr/lib/python3/dist-packages/middlewared/utils/cgroups.py", line 13, in move_to_root_cgroups Dec 28 13:06:29 freenas middlewared[70567]: with open(f"/sys/fs/cgroup/{new_name}/cgroup.procs", "w") as f2: Dec 28 13:06:29 freenas middlewared[70567]: FileNotFoundError: [Errno 2] No such file or directory: '/sys/fs/cgroup/unified/cgroup.procs' Dec 28 13:06:30 freenas middlewared[70570]: Process zettarepl: Dec 28 13:06:30 freenas middlewared[70570]: Traceback (most recent call last): Dec 28 13:06:30 freenas middlewared[70570]: File "/usr/lib/python3.9/multiprocessing/process.py", line 315, in _bootstrap Dec 28 13:06:30 freenas middlewared[70570]: self.run() Dec 28 13:06:30 freenas middlewared[70570]: File "/usr/lib/python3.9/multiprocessing/process.py", line 108, in run Dec 28 13:06:30 freenas middlewared[70570]: self._target(*self._args, **self._kwargs) Dec 28 13:06:30 freenas middlewared[70570]: File "/usr/lib/python3/dist-packages/middlewared/plugins/zettarepl.py", line 147, in __call__ Dec 28 13:06:30 freenas middlewared[70570]: move_to_root_cgroups(os.getpid()) Dec 28 13:06:30 freenas middlewared[70570]: File "/usr/lib/python3/dist-packages/middlewared/utils/cgroups.py", line 13, in move_to_root_cgroups Dec 28 13:06:30 freenas middlewared[70570]: with open(f"/sys/fs/cgroup/{new_name}/cgroup.procs", "w") as f2: Dec 28 13:06:30 freenas middlewared[70570]: FileNotFoundError: [Errno 2] No such file or directory: '/sys/fs/cgroup/unified/cgroup.procs' Dec 28 13:06:31 freenas middlewared[70580]: Process zettarepl:
