Hello I plan to migrate to new hardware. Is it possible to just add the old 4 HD ZFS pool and use it (HD order should be same)?
Migration from HP Proliant N36L to HP Proliant G8 (using on board controller, no additional one)
thanks for your response. What has to be done with the pool than?
I already did it and also saw the disk in the system but the pool itself was not imported. I stopped at that point as I was not sure what would happen while importing it.
I mounted the disks to the old server now for further checking and noting all settings
