Hi!
Something is seriously wrong with SMB in latest version(s). In 9.10.2 everything worked fine, but after upgrade to U2 and later windows clients cannot connect to shares. Rolled back to 9.10.2 and kept using it, but now u4 is needed for SambaCry. Did reset configuration and a fresh install on boot drive - the same. Tried to change permissions every possible way - nothing. But test with fresh install on other machine worked and it seems that newer install does like the zfs volume from previous installation. Log gives one interesting and repeating message when trying to access the share from windows machine(10.66.1.254):
Mountd should be daemon for NFS and should not have any business with SMB shares?! NFS share on the same machine works fine.
Any Ideas?
May 29 23:43:16 kkzfs01 mountd[21679]: mount request from 10.66.1.254 for non existent path /Data May 29 23:43:16 kkzfs01 mountd[21679]: mount request denied from 10.66.1.254 for /Data May 29 23:43:16 kkzfs01 mountd[21679]: mount request from 10.66.1.254 for non existent path /Data May 29 23:43:16 kkzfs01 mountd[21679]: mount request denied from 10.66.1.254 for /Data May 29 23:43:16 kkzfs01 mountd[21679]: mount request from 10.66.1.254 for non existent path /Data May 29 23:43:16 kkzfs01 mountd[21679]: mount request denied from 10.66.1.254 for /Data May 29 23:43:16 kkzfs01 mountd[21679]: mount request from 10.66.1.254 for non existent path /Data May 29 23:43:16 kkzfs01 mountd[21679]: mount request denied from 10.66.1.254 for /Data May 29 23:43:16 kkzfs01 mountd[21679]: mount request from 10.66.1.254 for non existent path /Data May 29 23:43:16 kkzfs01 mountd[21679]: mount request denied from 10.66.1.254 for /Data
Any Ideas?
