ian351c
- Oct 20, 2011
A funny thing happened on the way to FreeNAS 11-STABLE...
I've been running a FreeNAS 11 Nightly from 4/20/2017 for the last couple of months. I had formerly been running Corral, and decided to reinstall the nightly rather than to try to "downgrade" to 9.10. Anyways, this morning I saw that 11-RELEASE was out and wanted to get to the Stable train, so I installed 11-RELEASE via the command line (to force the updater from the Nightlies train to the Stable train). When the upgrade was completed, I couldn't access any of my SMB shares (though I see them listed). I could map the shares in MacOS, but it complained about not being able to access any files. Windows gave me the same type of message. I did some troubleshooting and some googling but couldn't come up with a smoking gun, so I rolled back to the Nightly. I then tried to upgrade using the 11-RELEASE CD image. But the same thing happened. Since I was expecting trouble this time, I had saved log.smbd and smb4.conf to compare between versions. It turns out, there are some interesting differences between the smb4.conf generated in 11-RELEASE vs the old Nightly I was running. The two major differences I noticed were that the share paths are all quoted now:
and that my vfs objects for each share had two objects removed:
Replacing the missing vfs objects in each share fixed my mounting issue.
Mostly I'm putting this here in case anyone else runs into this.
path = /shared/directory/on/nas -> path = "/shared/directory/on/nas"and that my vfs objects for each share had two objects removed:
vfs objects = zfs_space zfsacl streams_xattr aio_pthread ->
vfs objects = streams_xattr aio_pthreadReplacing the missing vfs objects in each share fixed my mounting issue.
