Scharbag
 - Feb 1, 2012
I have been using FreeNAS hosted on a VMware system successfully for a number of years and I am very happy with it.  I am currently using older server hardware, namely a Supermicro X8DTE-F dual processor motherboard with 192GB of ECC RAM and a pair of L5638 CPUs.  My SAS controllers are external units (2 @ LSI 9211-8i).  Everything works great and I have no need to upgrade.  That said, the old motherboard is no longer supported in any new releases of ESXi and at some point, it will fail due to age.
So, I would like to know what this community would recommend for a replacement.
I currently have (VMs run in ESXi - see signature for details):
FreeNAS with 4 simple jails (Media type stuff) and about ~79TiB of storage over 3 pools (fast - production - backup)
4-5 Windows 7 VMs
TrueCommand VM
1 Windows 10 VM
pfSense VM (I require 2 physical NICs)
The system does not see intensive processor loading as it stores data and serves media. I have so much memory because I got it for CHEAP from my old workplace. I would like to stick with server grade hardware as reliability is key. I certainly do not need bleeding edge or even leading edge hardware as my old slag works fine.
I was considering X10 type hardware. I would like to stick to at least 128GB of ram if possible. I think this forces me to use dual CPU boards. I would love to hear your opinions on how I should approach my motherboard end of life.
Thank you,
4-5 Windows 7 VMs
TrueCommand VM
1 Windows 10 VM
Thank you,
