-fun-
- Oct 27, 2015
Hi All,
after availability of iocage I migrated all my jails to iocage from iohyve. This was before the UI could handle this.
I had created all jails on the 11.1 release. After FreeNAS moved to 11.2 I found I could have the jails listed in the UI now but not migrate them to a current release. This does not work from the command line either. This fails:
This is a problem, because some software in my jails is long outdated but updates are not compatible with the 11.1 release.
Has anyone experienced the same problem?
Or is there any advice which would help work around the problem (apart from setting up new jails from scratch, which is an obvious workaround I very urgently want to avoid).
Complete description of the problem is here:
https://redmine.ixsystems.com/issues/78834
Unfortunately the migration of the ticket to Jira does not seem to have pushed this.
It seems not to have high priority (priority 'low', 'unscreened', affects versions: 'none', resolution: 'unresolved', ...). Also the ticket description in Jira more or less just refers to the old ticket without any own description of the issue.
https://jira.ixsystems.com/browse/NAS-101143
-fun-
iocage upgrade <jailname> -r 11.2-RELEASE
-fun-
