SOLVED Upgrade from TrueNAS-22.12.4.2 to TrueNAS-24.04-RC.1 fails right at the start of install
burmjohn
Hi All,
Hopefully you guys can help, Upgrade from TrueNAS-22.12.4.2 to TrueNAS-24.04-RC.1 fails right at the start of install. This is right after it warns me about WEBDAV and I click continue.
Error:
Error: Traceback (most recent call last): File "/usr/lib/python3/dist-packages/middlewared/job.py", line 427, in run await self.future File "/usr/lib/python3/dist-packages/middlewared/job.py", line 465, in __run_body rv = await self.method(*([self] + args)) File "/usr/lib/python3/dist-packages/middlewared/schema.py", line 1379, in nf return await func(*args, **kwargs) File "/usr/lib/python3/dist-packages/middlewared/plugins/update.py", line 285, in update await self.middleware.call('update.install', job, os.path.join(location, 'update.sqsh'), options) File "/usr/lib/python3/dist-packages/middlewared/main.py", line 1368, in call return await self._call( File "/usr/lib/python3/dist-packages/middlewared/main.py", line 1328, in _call return await self.run_in_executor(prepared_call.executor, methodobj, *prepared_call.args) File "/usr/lib/python3/dist-packages/middlewared/main.py", line 1231, in run_in_executor return await loop.run_in_executor(pool, functools.partial(method, *args, **kwargs)) File "/usr/lib/python3.9/concurrent/futures/thread.py", line 52, in run result = self.fn(*self.args, **self.kwargs) File "/usr/lib/python3/dist-packages/middlewared/plugins/update_/install_linux.py", line 32, in install self.middleware.call_sync("update.install_scale", mounted, progress_callback, options) File "/usr/lib/python3/dist-packages/middlewared/main.py", line 1398, in call_sync return methodobj(*prepared_call.args) File "/usr/lib/python3/dist-packages/middlewared/plugins/update_/install.py", line 52, in install_scale self._execute_truenas_install(mounted, command, progress_callback) File "/usr/lib/python3/dist-packages/middlewared/plugins/update_/install.py", line 83, in _execute_truenas_install raise CallError(result or f"Abnormal installer process termination with code {p.returncode}") middlewared.service_exception.CallError: [EFAULT] {'error': 'unsquashfs failed with exit code 1: SYNTAX: unsquashfs [options] filesystem [directories or files to extract]\n\t-v[ersion]\t\tprint version, licence and copyright information\n\t-d[est] <pathname>\tunsquash to <pathname>, default "squashfs-root"\n\t-q[uiet]\t\tno verbose output\n\t-n[o-progress]\t\tdon\'t display the progress bar\n\t-no[-xattrs]\t\tdon\'t extract xattrs in file system\n\t-x[attrs]\t\textract xattrs in file system (default)\n\t-u[ser-xattrs]\t\tonly extract user xattrs in file system.\n\t\t\t\tEnables extracting xattrs\n\t-p[rocessors] <number>\tuse <number> processors. By default will use\n\t\t\t\tnumber of processors available\n\t-i[nfo]\t\t\tprint files as they are unsquashed\n\t-li[nfo]\t\tprint files as they are unsquashed with file\n\t\t\t\tattributes (like ls -l output)\n\t-l\t\t\tlist filesystem, but don\'t unsquash\n\t-ll\t\t\tlist filesystem with file attributes (like\n\t\t\t\tls -l output), but don\'t unsquash\n\t-lln[umeric]\t\t-lls but with numeric uids and gids\n\t-lc\t\t\tlist filesystem concisely, displaying only files\n\t\t\t\tand empty directories. Don\'t unsquash\n\t-llc\t\t\tlist filesystem concisely with file attributes,\n\t\t\t\tdisplaying only files and empty directories.\n\t\t\t\tDon\'t unsquash\n\t-o[ffset] <bytes>\tskip <bytes> at start of <dest>\n\t\t\t\tOptionally a suffix of K, M or G can be given to specify\n\t\t\t\tKbytes, Mbytes or Gbytes respectively.\n\t\t\t\tDefault 0 bytes.\n\t-f[orce]\t\tif file already exists then overwrite\n\t-ig[nore-errors]\tTreat errors writing files to output as non-fatal\n\t-st[rict-errors]\tTreat all errors as fatal\n\t-s[tat]\t\t\tdisplay filesystem superblock information\n\t-UTC\t\t\tUse UTC rather than local time zone when displaying time\n\t-mkfs-time\t\tdisplay filesystem superblock time\n\t-fstime\t\t\tsynonym for -mkfs-time\n\t-e[f] <extract file>\tlist of directories or files to extract.\n\t\t\t\tOne per line\n\t-da[ta-queue] <size>\tSet data queue to <size> Mbytes. Default 256\n\t\t\t\tMbytes\n\t-fr[ag-queue] <size>\tSet fragment queue to <size> Mbytes. Default\n\t\t\t\t256 Mbytes\n\t-r[egex]\t\ttreat extract names as POSIX regular expressions\n\t\t\t\trather than use the default shell wildcard\n\t\t\t\texpansion (globbing)\n\nDecompressors available:\n\tgzip\n\tlzma\n\tlzo\n\tlz4\n\txz\n\tzstd\n'}
morganL
Captain Morgan
Administrator
Hi All,
Error:
suggest you report a bug... we may need to access your system since its a VM.
ABain
Bug Conductor
we support upgrade from the prior major release, you need to upgrade to cobia first and then dragonfish.
ABain
Bug Conductor
There is an error on the docs website showing the direct upgrade, this will be corrected shortly.
burmjohn
Thanks, will try shortly.
burmjohn
I can confirm upgrading to Cobia then DragonFish worked, thank you!
