Upgrade from Freenas 11.1-U7 to 11.3-U2 (CIFS/ SMB will not start)
ObiTobi
I have tried upgrade my perfect working 11.2-U7 to 11.3-U2 but no luck.
After reboot I receive alert "
New alerts:
* Attempt to connect to netlogon share failed with error: [EFAULT] could not obtain winbind interface details: Winbind daemon is not available.
could not obtain winbind domain name!
failed to call wbcPingDc: Winbind daemon is not available.. "
winbind logfile means "winbindd could not fetch our SID"
I'm nit sure if this is my problem but the smb4.conf from 11.3-U2 has a different entry
idmap config rjap.de: backend = rid
idmap config rjap.de: range = 20000-90000000
but my smb4.conf from 11.1.U7 means
idmap config RJAP: backend = rid
idmap config RJAP: range = 20000-90000000
Any idea whats going wrong here and what I can do?
Thanks
Redcoat
Latest FreeNAS version 11.3-U2.1 has a samba patch that may be a fix for you?
anodos
Sambassador
New alerts:
Thanks
Check your WORKGROUP in Services->SMB. It should be "RJAP" and not "rjap.de".
ObiTobi
I'm sorry - It was latest update - to U2.1
Thx, I will check it again
@anodos - perfect it work. But for me the big question - under 11.1.U7 was my WORKGROUP = RJAP, unter 11.3-U2.1 rjap.de
