freenas11.intra.lokal kernel log messages:
Ich habe
smb4.conf:
BUG oder Konfigurationsfehler?
Für jeden Tipp dankbar.
R.
> Failed to fully fault in a core file segment at VA 0x800936000 with size 0x3000 to be written at offset 0x2b8000 for process winbindd > Failed to fully fault in a core file segment at VA 0x804aca000 with size 0x16000 to be written at offset 0x62e000 for process winbindd > pid 86473 (winbindd), uid 0: exited on signal 6 (core dumped) -- End of security output --
Ich habe
FreeNAS-11.1-U4 in einer Proxmox (KVM) mit 8 GByte RAM zum Testen installiert. Freenas wurde in die Domäne aufgenommen und eine Freigabe (SMB) erstellt.
smb4.conf:
[global] encrypt passwords = yes dns proxy = no strict locking = no oplocks = yes deadtime = 15 max log size = 51200 max open files = 234803 logging = file load printers = no printing = bsd printcap name = /dev/null disable spoolss = yes getwd cache = yes guest account = nobody map to guest = Bad User obey pam restrictions = yes ntlm auth = no directory name cache size = 0 kernel change notify = no panic action = /usr/local/libexec/samba/samba-backtrace nsupdate command = /usr/local/bin/samba-nsupdate -g server string = FreeNAS Server ea support = yes store dos attributes = yes lm announce = yes hostname lookups = yes acl allow execute always = true dos filemode = yes multicast dns register = yes domain logons = no idmap config *: backend = tdb idmap config *: range = 90000001-100000000 server role = member server workgroup = INTRANET realm = INTRA.LOKAL security = ADS client use spnego = yes local master = no domain master = no preferred master = no ads dns update = yes winbind cache time = 7200 winbind offline logon = yes winbind enum users = yes winbind enum groups = yes winbind nested groups = yes winbind use default domain = no winbind refresh tickets = yes idmap config INTRANET: backend = rid idmap config INTRANET: range = 20000-90000000 allow trusted domains = no client ldap sasl wrapping = plain template shell = /bin/sh template homedir = /home/%D/%U netbios name = FREENAS11 create mask = 0666 directory mask = 0777 client ntlmv2 auth = yes dos charset = CP437 unix charset = UTF-8 log level = 1 nt pipe support = no [Daten] path = "/mnt/Daten/Daten" printable = no veto files = /.snapshot/.windows/.mac/.zfs/ writeable = yes browseable = yes access based share enum = yes vfs objects = zfs_space zfsacl dfs_samba4 streams_xattr hide dot files = no guest ok = no nfs4:mode = special nfs4:acedup = merge nfs4:chown = true zfsacl:acesort = dontcare
R.
