woder
- Dec 30, 2017
Hey everyone,
I'm not too sure what else to do about this problem as I've already tried so many different things along with spending hours on this forum searching for answers. Anyways, everything seems to work with AD as far as the server is concerned. I can run all the different wbinfo outputs (all my users with -u, a test connection with -t) and everything works nicely.
The problem comes when I try to connect to the smb shares. No matter what I try I always get "The system could not contact a domain controller to service the authentication request". I don't understand why I am getting this error if the server is connected to the AD successfully and I can query the controller from the command line on freenas.
It's also worth noting that if I navigate to \\freenas\ I can't see any of my shares, even though they are all listed as browsable by network clients.
I would suspect the domain controller as a possible culprit except that all the windows computers in the domain can still auth correctly.
Any help is appreciated,
Thanks!
smb.conf:
Thanks!
smb.conf:
[global] server min protocol = SMB2 server max protocol = SMB3 encrypt passwords = yes dns proxy = no strict locking = no oplocks = yes deadtime = 15 max log size = 51200 max open files = 468614 logging = file load printers = no printing = bsd printcap name = /dev/null disable spoolss = yes getwd cache = yes guest account = nobody map to guest = Bad User obey pam restrictions = yes directory name cache size = 0 kernel change notify = no panic action = /usr/local/libexec/samba/samba-backtrace nsupdate command = /usr/local/bin/samba-nsupdate -g server string = FreeNAS Server ea support = yes store dos attributes = yes lm announce = yes acl allow execute always = true dos filemode = yes multicast dns register = yes domain logons = no idmap config *: backend = tdb idmap config *: range = 90000001-100000000 server role = member server workgroup = WINC realm = WINC.LAN security = ADS client use spnego = yes cache directory = /var/tmp/.cache/.samba local master = no domain master = no preferred master = no ads dns update = yes winbind cache time = 7200 winbind offline logon = yes winbind enum users = yes winbind enum groups = yes winbind nested groups = yes winbind use default domain = no winbind refresh tickets = yes idmap config WINC: backend = rid idmap config WINC: range = 20000-90000000 allow trusted domains = no client ldap sasl wrapping = plain template shell = /bin/sh template homedir = /home/%D/%U netbios name = FREENAS netbios aliases = FREENAS pid directory = /var/run/samba create mask = 0666 directory mask = 0777 client ntlmv2 auth = yes dos charset = CP437 unix charset = UTF-8 log level = 10 [store] path = /mnt/Storage printable = no veto files = /.snapshot/.windows/.mac/.zfs/ writeable = yes browseable = yes vfs objects = zfs_space zfsacl aio_pthread hide dot files = yes guest ok = no nfs4:mode = special nfs4:acedup = merge nfs4:chown = true zfsacl:acesort = dontcare
