victorhooi
- Mar 16, 2012
I have a HP Proliant N40L Microserver, that previously has FreeNAS 92
It has four SATA drives, and FreeNAS 9.2 (Beta, I can't recall which build) installed on a USB stick.
I recently decided to wipe the USB stick, and install FreeNAS 9.3. release onto it.
However, during the boot, I'm getting a whole bunch of error messages about "CAM Status: ATA Status Error" and "
ATA status: 51 (DRDY SERV ERR), error: 40 (UNC )"
on what I believe is the USB stick (/dev/ada1 - the SATA drives shouldn't have been mounted at this point).
I've tried two different USB sticks (one of which is known good, and the other is the one that was previously running 9.2 Beta successfully for several months), and it exhibits the same symptoms each time.
Eventually, it does finish booting, if you leave it long enough - however, then when you try to run the initial wizard from a web browser, it then prints out those errors again, and hangs.
Any thoughts on what's going on, or what the next diagnosis steps might be?
