Upgrade from 9.10 to 11 fails
SoulRaven
I have try to upgrade from 9.10 to 11 and the upgrade fails, without any success.
i have attached the photo of the fail and stack dump:
Jailer
Not strong, but bad
What's the hardware?
SoulRaven
HP Microserver G8
Intel(R) Celeron(R) CPU G1610T @ 2.30GHz
16Gb RAM
2XToshiba MD03ACAxxxV 3TB SATA-III 7200 RPM 64MB
CJDK
Dif you find a solution.
I have same problem also with hp gen 8
Kam
Have you created bug for this or you resolved the issue?
I have also HP microserver gen 8 and wondering if I should try to update.
Hjrr
I also had a failure of upgrading 9.10 to 11.0 , system re-boots after d/l and install updates but gets stuck at some kind of error. Oh well at least it was virtualize and I already moved all the data off the drive to a real FreeNAS box.
