Martin Jones
 - Feb 9, 2016
HP Gen 8 Microserver FreeNAS-11.1-U1
Platform Intel(R) Xeon(R) CPU E3-1230 V2 @ 3.30GHz
Memory 16311MB
Relative Newbie
I upgraded from 9.10 to 11.1 on Friday and received this horrible security run on Saturday. After searching google for ACPI and Loopback error responses, there seems to be something wrong with my BIOS, and hope that an update from HP will fix this. I would like some clarification before I start to change anything. Fortunately, everything seems to be working fine, although the minute I said it I felt like I was tempting fate! I hope I'm panicking for nothing!
Memory 16311MB
Relative Newbie
freenas.local daily security run output freenas.local changes in mounted filesystems: 3c3 < Jails/.warden-template-standard /mnt/Jails/.warden-template-standard zfs rw,nfsv4acls 0 0 --- > Jails/.warden-template-standard-10.3-x64 /mnt/Jails/.warden-template-standard-10.3-x64 zfs rw,nfsv4acls 0 0 17c17 < freenas-boot/ROOT/9.10.2-U6 / zfs rw,noatime,nfsv4acls 0 0 --- > freenas-boot/ROOT/11.1-U1 / zfs rw,noatime,nfsv4acls 0 0 22a23 > tmpfs /var/db/collectd/rrd tmpfs rw 0 0 freenas.local kernel log messages: > Copyright (c) 1992-2017 The FreeBSD Project. > FreeBSD 11.1-STABLE #0 r321665+4bd3ee42941(freenas/11.1-stable): Thu Jan 18 15:45:01 UTC 2018 > root@gauntlet:/freenas-11-releng/freenas/_BE/objs/freenas-11-releng/freenas/_BE/os/sys/FreeNAS.amd64 amd64 > FreeBSD clang version 5.0.0 (tags/RELEASE_500/final 312559) (based on LLVM 5.0.0svn) > CPU: Intel(R) Xeon(R) CPU E3-1230 V2 @ 3.30GHz (3292.60-MHz K8-class CPU) > avail memory = 16566521856 (15799 MB) > FreeBSD/SMP: 1 package(s) x 4 core(s) x 2 hardware threads > ACPI BIOS Warning (bug): 32/64X length mismatch in FADT/Pm1aControlBlock: 16/32 (20170728/tbfadt-748) > ACPI BIOS Warning (bug): 32/64X length mismatch in FADT/Pm2ControlBlock: 8/32 (20170728/tbfadt-748) > ACPI BIOS Warning (bug): Invalid length for FADT/Pm1aControlBlock: 32, using default 16 (20170728/tbfadt-850) > ACPI BIOS Warning (bug): Invalid length for FADT/Pm2ControlBlock: 32, using default 8 (20170728/tbfadt-850) > SMP: AP CPU #1 Launched! > SMP: AP CPU #2 Launched! > SMP: AP CPU #6 Launched! > SMP: AP CPU #3 Launched! > SMP: AP CPU #7 Launched! > SMP: AP CPU #4 Launched! > SMP: AP CPU #5 Launched! > Timecounter "TSC-low" frequency 1646298798 Hz quality 1000 > random: entropy device external interface > random: registering fast source Intel Secure Key RNG > random: fast provider: "Intel Secure Key RNG" > nexus0 > aesni0: <AES-CBC,AES-XTS,AES-GCM,AES-ICM> on motherboard > padlock0: No ACE support. > atrtc0: registered as a time-of-day clock, resolution 1.000000s > pcib0: _OSC returned error 0x10 > pci1: <ACPI PCI bus> on pcib1 > ehci0: <Intel Cougar Point USB 2.0 controller> mem 0xfacf0000-0xfacf03ff irq 21 at device 26.0 on pci0 > usbus0: 480Mbps High Speed USB v2.0 > pci3: <ACPI PCI bus> on pcib3 > pci4: <ACPI PCI bus> on pcib4 > bge0: <Broadcom BCM5720 A0, ASIC rev. 0x5720000> mem 0xfabf0000-0xfabfffff,0xfabe0000-0xfabeffff,0xfabd0000-0xfabdffff irq 16 at device 0.0 on pci4 > bge1: <Broadcom BCM5720 A0, ASIC rev. 0x5720000> mem 0xfabc0000-0xfabcffff,0xfabb0000-0xfabbffff,0xfaba0000-0xfabaffff irq 17 at device 0.1 on pci4 > pci5: <ACPI PCI bus> on pcib5 > xhci0: <XHCI (generic) USB 3.0 controller> mem 0xfbff0000-0xfbff1fff irq 18 at device 0.0 on pci5 > xhci0: Unable to map MSI-X table > usbus1: 5.0Gbps Super Speed USB v3.0 > pci6: <ACPI PCI bus> on pcib6 > vgapci0: <VGA-compatible display> mem 0xf9000000-0xf9ffffff,0xfbee0000-0xfbee3fff,0xfb000000-0xfb7fffff irq 16 at device 0.1 on pci6 > uhci0: <HP iLO Standard Virtual USB controller> port 0x4000-0x401f irq 16 at device 0.4 on pci6 > usbus2: 12Mbps Full Speed USB v1.0 > ehci1: <Intel Cougar Point USB 2.0 controller> mem 0xface0000-0xface03ff irq 20 at device 29.0 on pci0 > usbus3: 480Mbps High Speed USB v2.0 > pci7: <PCI bus> on pcib7 > acpi_syscontainer0: <System Container> port 0x2e-0x2f on acpi0 > uart1: <Non-standard ns8250 class UART with FIFOs> at port 0x2f8 irq 3 on isa0 > est: cpu_vendor GenuineIntel, msr 221b00002300 > est: cpu_vendor GenuineIntel, msr 221b00002300 > est: cpu_vendor GenuineIntel, msr 221b00002300 > est: cpu_vendor GenuineIntel, msr 221b00002300 > est: cpu_vendor GenuineIntel, msr 221b00002300 > est: cpu_vendor GenuineIntel, msr 221b00002300 > est: cpu_vendor GenuineIntel, msr 221b00002300 > freenas_sysctl: adding account. > freenas_sysctl: adding directoryservice. > freenas_sysctl: adding middlewared. > freenas_sysctl: adding network. > freenas_sysctl: adding services. > nvme cam probe device init > ugen2.1: <HP UHCI root HUB> at usbus2 > ugen1.1: <0x1912 XHCI root HUB> at usbus1 > ugen3.1: <Intel EHCI root HUB> at usbus3 > ugen0.1: <Intel EHCI root HUB> at usbus0 > uhub0: <HP UHCI root HUB, class 9/0, rev 1.00/1.00, addr 1> on usbus2 > uhub1: <Intel EHCI root HUB, class 9/0, rev 2.00/1.00, addr 1> on usbus0 > uhub2: <0x1912 XHCI root HUB, class 9/0, rev 3.00/1.00, addr 1> on usbus1 > uhub3: <Intel EHCI root HUB, class 9/0, rev 2.00/1.00, addr 1> on usbus3 > uhub2: 6 ports with 6 removable, self powered > uhub3: 2 ports with 2 removable, self powered > ugen2.2: <BMC Virtual Keyboard> at usbus2 > ukbd0 on uhub0 > ukbd0: <Virtual Keyboard > on usbus2 > kbd2 at ukbd0 > ugen0.2: <vendor 0x8087 product 0x0024> at usbus0 > uhub4 on uhub1 > uhub4: <vendor 0x8087 product 0x0024, class 9/0, rev 2.00/0.00, addr 2> on usbus0 > ugen3.2: <vendor 0x8087 product 0x0024> at usbus3 > uhub5 on uhub3 > uhub5: <vendor 0x8087 product 0x0024, class 9/0, rev 2.00/0.00, addr 2> on usbus3 > ugen3.3: <vendor 0x0424 product 0x2660> at usbus3 > uhub6 on uhub5 > ugen0.3: <SanDisk Cruzer Fit> at usbus0 > umass0 on uhub4 > umass0:5:0: Attached to scbus5 > random: unblocking device. > ada0: da0 at umass-sim0 bus 0 scbus5 target 0 lun 0 > <WDC WD30EFRX-68EUZN0 82.00A82> ACS-2 ATA SATA 3.x device > ada0: 600.000MB/s transfers (SATA 3.x, da0: <SanDisk Cruzer Fit 1.00> Removable Direct Access SPC-4 SCSI device > UDMA5, PIO 8192bytes) > da0: Serial Number 4C530000160114105584 > da0: 40.000MB/s transfers > da0: 15264MB (31260672 512 byte sectors) > da0: quirks=0x2<NO_6_BYTE> > Trying to mount root from zfs:freenas-boot/ROOT/11.1-U1 []... > GEOM_RAID5: Module loaded, version 1.3.20140711.62 (rev f91e28e40bf7) > GEOM_MIRROR: Device mirror/swap0 launched (2/2). > GEOM_MIRROR: Device mirror/swap1 launched (2/2). > GEOM_ELI: Device mirror/swap0.eli created. > GEOM_ELI: Device mirror/swap1.eli created. > hwpmc: SOFT/16/64/0x67<INT,USR,SYS,REA,WRI> TSC/1/64/0x20<REA> IAP/4/48/0x3ff<INT,USR,SYS,EDG,THR,REA,WRI,INV,QUA,PRC> IAF/3/48/0x67<INT,USR,SYS,REA,WRI> > bge0: link state changed to DOWN > ums0 on uhub0 > ums0: <Virtual Mouse> on usbus2 > bge0: link state changed to UP > epair0a: Ethernet address: 02:71:50:00:05:0a > epair0b: Ethernet address: 02:71:a0:00:06:0b > ifa_maintain_loopback_route: deletion failed for interface epair0b: 3 > epair0a: Ethernet address: 02:71:50:00:05:0a > epair0b: Ethernet address: 02:71:a0:00:06:0b > ifa_maintain_loopback_route: deletion failed for interface lo0: 48 > ugen2.2: <BMC Virtual Keyboard> at usbus2 (disconnected) > ukbd0: at uhub0, port 1, addr 2 (disconnected) > ukbd0: detached > ums0: at uhub0, port 1, addr 2 (disconnected) > ums0: detached > ifa_maintain_loopback_route: deletion failed for interface epair0b: 3 > epair0a: Ethernet address: 02:71:50:00:05:0a > epair0b: Ethernet address: 02:71:a0:00:06:0b > ifa_maintain_loopback_route: deletion failed for interface lo0: 48 -- End of security output --
