Upgrade/downgrade.
Jason Evans
Just wanted to shoot a quick update. Everything has been ordered. Case already arrived, I will take pics and update the OP with them as more stuff arrives. :)
Chris Moore
What did you actually end up ordering?
Jason Evans
Case was the LIAN-LI A75.
Cpu, mobo, and heat sink you recommended. I ordered several of the cables you linked as well, the forward break out, the SAS expander card. Everything you suggested minus the pci-e extender. Also ordered a few odds and ends for an "incase" moment. Longer single sata data cables, some male 4 pin molex to female sata power 6 on each and 2 of them. Um. Extra TIM, some air. A USB header to USB dongle.
Think that's it lol.
Sent from my SM-N950U using Tapatalk
Chris Moore
Please keep us updated on your build. How is it going?
Jason Evans
It's done and fired up. I'm going to be uploading the pics I took along the way while building it. Was thinking if doing a build thread, cause I had a few issues? Thoughts? Or should I just update OP with a big "edit"?
Chris Moore
Sure, make a build thread, just put a link here so it is easy to get from this one to that one.
If you have any questions, ask. There are lots of folks on the forum that would love to help you any way we can.
Jason Evans
Ok sweet. I'll definitely do that when it's done. I appreciate your help with picking out these upgrades.
