SOLVED updating 11.2 Stable fails in SHELL and GUI
w.reidlinger
When I'm trying to update my FreeNAS 11.2 Stable I see the following:
root@freenas[~]# freenas-update check
Delete package docs
Upgrade package base-os 11.2-RC1-d2f5bbb81785fcff78abaf7e4a32bb6e->11.2-RC2-bf9b90e1b8bac432ae62f57b929efc9d
Upgrade package freebsd-pkgdb 11.2-RC1-d2f5bbb81785fcff78abaf7e4a32bb6e->11.2-RC2-bf9b90e1b8bac432ae62f57b929efc9d
Upgrade package freenas-pkg-tools 11.2-RC1-d2f5bbb81785fcff78abaf7e4a32bb6e->11.2-RC2-bf9b90e1b8bac432ae62f57b929efc9d
Upgrade package FreeNASUI 11.2-RC1-d2f5bbb81785fcff78abaf7e4a32bb6e->11.2-RC2-bf9b90e1b8bac432ae62f57b929efc9d
Reboot is (conditionally) required
Sequence d2f5bbb81785fcff78abaf7e4a32bb6e -> bf9b90e1b8bac432ae62f57b929efc9d
So than I want to apply the updates:
root@freenas[~]# freenas-update update
awk: newline in string freenas-boot/ROOT/11... at source line 1
In the GUI I can see the following Error if I want to fetch and install the updates.
Update
'NoneType' object is not iterable
(see screenshot)
Any ideas?
D
dlavigne
Guest
Which version are you on now and which version are you trying to update to? Did you run a Nightlies at any point?
w.reidlinger
I'm running:
OS Version: FreeNAS-11.2-RC1 (Build Date: Oct 17, 2018 23:38)
I just tried to update my current running version to the version which is available via the GUI, nothing special.
The following information I see in the GUI:
Operation Name Delete docs-11.2-RC1-d2f5bbb81785fcff78abaf7e4a32bb6e Upgrade base-os-11.2-RC1-d2f5bbb81785fcff78abaf7e4a32bb6e -> base-os-11.2-RC2-bf9b90e1b8bac432ae62f57b929efc9d Upgrade freebsd-pkgdb-11.2-RC1-d2f5bbb81785fcff78abaf7e4a32bb6e -> freebsd-pkgdb-11.2-RC2-bf9b90e1b8bac432ae62f57b929efc9d Upgrade freenas-pkg-tools-11.2-RC1-d2f5bbb81785fcff78abaf7e4a32bb6e -> freenas-pkg-tools-11.2-RC2-bf9b90e1b8bac432ae62f57b929efc9d Upgrade FreeNASUI-11.2-RC1-d2f5bbb81785fcff78abaf7e4a32bb6e -> FreeNASUI-11.2-RC2-bf9b90e1b8bac432ae62f57b929efc9d
Just tried it again, still getting this error in the GUI:
Update 'NoneType' object is not iterable
No I installed version 11.2-RC1 and never did a Nightlies update at any point.
D
dlavigne
Guest
Interesting. If the issue persists when RELEASE is available tomorrow, please create a report at bugs.freenas.org.
w.reidlinger
Just updated the system and it worked out perfectly!
Thanks,
OS Version: FreeNAS-11.2-RELEASE (Build Date: Dec 5, 2018 21:28)
