updated sabnzbd plugin. VNET Error. Rebooted. No Plugins starting
i recently went to update SABNZBD to the latest version via the FreeNas plugin screen. After updating, I received an error that plugin couldnt start due to vnet error. I rebooted Freenas and then all of my plugins - Radarr, Sonarr, SAB would not start. Did some trouble shooting and changed the NIC's to DHCP. Here are the outputs when i try to start them all from command line.
####All 3 Jails have same output#######
root@freenas[~]# iocage start radarr
No default gateway found for ipv6.
* Starting radarr
+ Started OK
+ Using devfs_ruleset: 5
+ Configuring VNET OK
+ Using IP options: vnet
+ Starting services FAILED
ERROR:
[b'']
Refusing to start radarr: exec_start failed
Updated to latest available version.
Version:
FreeNAS-11.3-U4.1
Any ideas to get these up are apprecated.
output from my middlewared.log
File "/usr/local/lib/python3.7/site-packages/middlewared/job.py", line 349, in run
await self.future
File "/usr/local/lib/python3.7/site-packages/middlewared/job.py", line 387, in __run_body
rv = await self.middleware.run_in_thread(self.method, *([self] + args))
File "/usr/local/lib/python3.7/site-packages/middlewared/utils/run_in_thread.py", line 10, in run_in_thread
return await self.loop.run_in_executor(self.run_in_thread_executor, functools.partial(method, *args, **kwargs))
File "/usr/local/lib/python3.7/site-packages/middlewared/utils/io_thread_pool_executor.py", line 25, in run
File "/usr/local/lib/python3.7/site-packages/middlewared/schema.py", line 965, in nf
return f(*args, **kwargs)
File "/usr/local/lib/python3.7/site-packages/middlewared/plugins/jail.py", line 1133, in start
raise CallError(str(e))
middlewared.service_exception.CallError: [EFAULT] + Starting services FAILED
ERROR:
[b'']
/var/log/messages
root@freenas[/var/log]# tail -f messages
Aug 24 09:43:20 freenas kernel: epair0a: link state changed to UP
Aug 24 09:43:20 freenas kernel: epair0b: link state changed to UP
Aug 24 09:43:20 freenas kernel: epair0a: changing name to 'vnet0.29'
Aug 24 09:43:20 freenas kernel: pid 17138 (ifconfig), jid 29, uid 0: exited on signal 11
Aug 24 09:43:21 freenas kernel: pid 17159 (sh), jid 29, uid 0: exited on signal 11
Aug 24 09:43:21 freenas kernel: vnet0.29: link state changed to DOWN
Aug 24 09:43:21 freenas kernel: epair0b: link state changed to DOWN
