Gaspetaahl
- Sep 13, 2018
today I updated my Truenas Core server to 12.0-U3.1 from 12.0-U3 but after that my samba shares stopped working. My smb4.conf looks like this:
and the smb4_share.conf looks like this:
I had a similar issue after the last update where also pdbedit -L didnt show any users. Now pdbedit -L shows all my users. Last time I could fix this with disabling and then reenabling my shares in the Truenas UI. But this time this did not work.
The error I see when using smbclient looks like this:
Windows says that the security policies of my organization dont allow access.
mount -t cifs shows:
# # SMB.CONF(5) The configuration file for the Samba suite # $FreeBSD$ # [global] dns proxy = No aio max threads = 2 max log size = 5120 load printers = No printing = bsd disable spoolss = Yes dos filemode = Yes kernel change notify = No directory name cache size = 0 nsupdate command = /usr/local/bin/samba-nsupdate -g unix charset = UTF-8 log level = 1 auth_json_audit:3@/var/log/samba4/auth_audit.log obey pam restrictions = False enable web service discovery = True logging = file server min protocol = SMB2_02 unix extensions = No map to guest = Bad User server string = FreeNAS Server bind interfaces only = Yes netbios name = freenas netbios aliases = server role = standalone workgroup = WORKGROUP idmap config *: backend = tdb idmap config *: range = 90000001-100000000 registry shares = yes include = registry
# # SMB.CONF(5) The configuration file for the Samba suite # $FreeBSD$ # [WG] path = /mnt/Volume1/WG read only = no guest ok = yes nfs4:chown = true ea support = false vfs objects = zfs_space zfsacl streams_xattr [User] path = /mnt/Volume1/User/%U access based share enum = yes read only = no guest ok = no nfs4:chown = true ea support = false vfs objects = zfs_space zfsacl streams_xattr ixnas:zfs_auto_homedir = true [User2] path = /mnt/Volume1/User2 read only = no guest ok = no nfs4:chown = true ea support = false vfs objects = zfs_space zfsacl streams_xattr [VM-Data] path = /mnt/Volume1/VM-Data browseable = no read only = no guest ok = no nfs4:chown = true ea support = false vfs objects = zfs_space zfsacl streams_xattr
$ smbclient //freenas.lan/WG -u alpine tree connect failed: NT_STATUS_BAD_NETWORK_NAME
mount error(95): Not supported Refer to the mount.cifs(8) manual page (e.g. man mount.cifs) and kernel log messages (dmesg) mount: mounting //freenas/WG$ on /home/user/mnt/WG failed: Not supported
