Update Photorprism, how?
quart
I have been running Scale and Photoprism fo month now and am very happy with that.
But I see that the installed version of Photoprism is 220901_1.0.11 and the latest on there site is Build 221223
I dont get the "update button", can I do it manually or is that something that IX Systems has to do?
You need to wait for the chart to be updated.
quart
Yes there is a offical app
LarsR
Truecharts current version is 221118_13.0.18 and generally get's more frequent updates then the official versions. so maybe you'd consider switching to using the truecharts version.
quart
Thanks but I have put very much time into my Photorprism, faces, albums etc.
And I dont know how to backup and restore all.
