Jrod696
- Nov 20, 2017
I have been using the Emby plugin for quite a while and now have a fire stick, playing on the Firestick you receive and error when playing HEVC files. I went through the testing and debugging on the Emby forums (see link below) and it was determined the FFMpeg is way out of date and most likely the cause. I waited to upgrade to 3.2.70.0 to see if that resolved the issue but it did not.
I have also tested on 3 separate sticks and they all have the issue.
How can I upgrade/update the FFMpeg in the Emby plugin jail without totally screwing up the whole jail.
I know it will be brought up so I will answer the question now, I do not want to do a manual install because the plugin does have features in it that are not included in the manual install and they work well for what I need.
https://emby.media/community/index.php?/topic/55354-fire-stick-hevc-error/
One last thing to add, I am very new to FreeNAS and scripting in general so I need the kindergarten instructions if possible
