Hello Everybody
I am running TrueNAS-12.0-U4.1 and noticed some unscheduled and unexpected system reboots every now and then. I started to see this issue with 12U1 already. At that point it happened very rarely and I did not bothered about it. However, I see those reboots more frequent these days and thus had a look in the logs but did not find anything except a reboot out of the blue...
Jul 31 00:51:34 SAXNAS03 kernel: lo0: link state changed to UP
Jul 31 00:54:35 SAXNAS03 kernel: in6_purgeaddr: err=65, destination address delete failed
Jul 31 02:53:51 SAXNAS03 syslog-ng[3764]: syslog-ng starting up; version='3.29.1'
Jul 31 02:53:51 SAXNAS03 ---<<BOOT>>---
Does anybody else see such behavior as well?
Is there a way to get more detailed logging? I have the option "System/General/Other Options/Crash Reporting" checked. I have set the syslog settings in "System/Advanced" set to debug and checked "enabled kernel debug". Does this do any good to get more detailed login? Would you recommend some additional measures to get to the bottom of these unscheduled system reboots?
Any help is much appreciated!
Regards
Chris
Regards
Chris
