imthenachoman
 - Oct 21, 2018
My parents have a FreeNAS server that was built for them. The system has gone to crap. I cannot boot from USB, if I try to do transfer from it the system crashes, if I do a
My hope is I could some how "unraid" the disks in it and retain data on specific disks so I could just unplug the disks and plug them into another computer I have. The other computer only has 2 SATA ports so I cannot move all the disks at one time.
The system has 5 disks:
If I click on the first backup and check volume status this is what I see:
Since
The end goal is being able to plug each disk, one at a time, into another computer to get the data off of it.
			 du - sh (from a shell via the web or SSH) it freezes. I don't have time to try to figure out what is wrong and I am not experienced with FreeNAS.My hope is I could some how "unraid" the disks in it and retain data on specific disks so I could just unplug the disks and plug them into another computer I have. The other computer only has 2 SATA ports so I cannot move all the disks at one time.
- ada0 - 80 GB
 - ada1 - 2 TB
 - ada2 - 2 TB
 - ada3 - 2 TB
 - ada4 - 2 TB
| Name | Used | Available | Compression | Compression Ratio | Status | Readonly | Comments | |---------------|---------------|-----------|---------------|-------------------|---------|---------------|----------| | backup | 3.6 TiB (49%) | 3.7 TiB | - | - | HEALTHY | | | | backup | 2.6 TiB (51%) | 2.5 TiB | lz4 | 1.18x | - | inherit (off) | | | one | 1.3 TiB (33%) | 2.5 TiB | inherit (lz4) | 1.18x | - | inherit (off) | | | two | 1.8 GiB (0%) | 2.5 TiB | inherit (lz4) | 1.16x | - | inherit (off) | | | three | 1.3 TiB (35%) | 2.5 TiB | inherit (lz4) | 1.18x | - | inherit (off) | | | four | 4.5 GiB (0%) | 2.5 TiB | inherit (lz4) | 1.61x | - | inherit (off) | |
backup raidz1-0 ada4p2 ada3p2 ada2p2 ada1p2
Since
 one,  two,  three,  four, are all smaller than 2 TB, I thought I could some how "unraid" the disks and put the data in those volumes/folders/??? into different disks. The end goal is being able to plug each disk, one at a time, into another computer to get the data off of it.
